Tire size advice
Howzit,
Getting ready to pull the trigger on staggered wheels. Leaning toward Ruff R280 in chrome. Fronts are 18 X 8.5/rear 18 X 9.5. The supplier insists the front tires should be 40 series and rear 35.
For a stretched look I think I want 225/35 front & 255/35 rear. Should I run 40 series in the front for a more kush ride?
Mahalo for your comments.
Is your car dropped/lowered? If you're not, your ride might look weird with the low profile tires because your car will have a big gap.
I don't think you will get the stretched look with those sizes and widths. Do you want a stretch for looks or for clearance?
I'm lowered on coilovers. The tire stretch would be for clearance. They originally wanted to put 245/40 front & 275/35 rear. I'm not sure if I would have fender rubbing going on with those sizes.
19x11.5 -51
you are in hawaii.... Dont run those wheels.. you have shops out there with amazing looking cars.
they will be sunk. message rev01 i believe. just do a little research on the wheels you want.
what suspension are you on or planning on running ? all good questions. also Never run the suggestion from the dealer if you want to have good wheels . they are Never going to be what you want. run 350z wheel sizes more aggressive for when you lower you car better fitment, just little help
Cypress
Wheels, Tires & Brakes Forum
02-28-05 03:01 PM
