Gs300 I want HID's but need help!
Old 12-15-09, 07:41 AM
skiz88
skiz88's Avatar
Default Gs300 I want HID's but need help!
I'm interested in installing an HID kit in my 01 gs300 l-tuned version. I nearly bought a kit until I read about glare issues with installing HID's in OEM llight housings.
Has anyone installed HID's in their oem light housings on an 01 gs300?? I really do not want to go through the trouble of changing out the housings to projector style.
Any help is appreciated.
Old 12-15-09, 07:57 AM
skiz88
skiz88's Avatar
Forgot to mention, for all I know the stock gs300 housings may already be projector style but I don't know how to tell the difference. Does anyone know?
Old 12-15-09, 09:55 AM
fro20
fro20's Avatar
they are not projectors. Projectors have a convex piece of glass infront of the bulb to spread out the light and project it in a particular pattern. The gs300 uses a reflector housing to accomplish this (from what I understand about the different lamp)
You can retro in some projectors, or swap an entie housing to a gs300/400/430 housing that has hids, or change out the bowl in the lamp from your gs lamp to the bowl from a HID equiped lamp.
The last one would be most easliy accomplished a pick n pull junk yard if you are lucky enough to find a gs3/4 with HIDS that have no beened cannablized.
Easiest solution, find HID lamps for about $600 a pair on ebay and they are driect bolt in swap with only minimal wiring mod to connect to ballast.
Old 12-15-09, 11:49 AM
Infamous 1
Infamous 1's Avatar
You can install the HIDs into the headlights no problem, but it won't have the cut off line like the projectors do. Many people on here are running HIDs with no projectors. GL
Old 12-15-09, 11:57 AM
trance565
trance565's Avatar
i've got 15k's in my headlights, they are non projector and work just fine, i would suggest polishing the housing if it's gotten dirty though, so it's nice and clear.
Old 12-15-09, 12:03 PM
LuxuryMods
Former Sponsor
LuxuryMods's Avatar
We can help you with Retrofitting if that is your route, nothing beats a retrofit for output.
15k headlights is too colorful, great for show, not so much for daily driving. 4300k-6000k would be the most for daily driving.
Here's a retro we just finished for a customer: Q45 into 2GS
Old 12-15-09, 12:56 PM
PHML
Master Thread Closer!!
PHML's Avatar
The 2GS comes in stock HID vs. stock Non-HID housings.
The stock HID housing was designed for its reflector bowl to create a nice cutoff line.
The stock Non-HID housing does not....and thus, installing an aftermarket HID kit in this housing will create glare to on-coming drivers.
With that being said...many members have done this....and manually adjusted the beam lower....and/or even added eyelids. I did both years ago....but has since gone with a projector type housing.
Pete
Old 12-15-09, 02:44 PM
o6spdracer
o6spdracer's Avatar
Just make sure you get a quality HID kit. I have the Xenon Depot kit for the headlights and fogs. I will eventually do the projectors for the cleaner cutoff, but the HIDs from Xenon Depot are awesome.
Old 12-15-09, 06:43 PM
skiz88
skiz88's Avatar
Default Re
Pete you mentioned some gen 2s have projector lenses. How can I tell if mine does?
Also someone mentioned pointing the bulbs if I decide to install in oem housing(assuming they are reflector style). It's my understanding the bulbs are plug n play. If that is the case, how do you aim them? Wouldn't they just twist in place?
To one of the comments above regarding color, after researching I'm really only interested in 4300, 5000 or maybe 6000k. I don't want it to be too blue or colorful and most of all I want to see better. I can't see a thing without the high beams on dark roads.
Old 12-15-09, 06:47 PM
skiz88
skiz88's Avatar
Sorry I should have read better. Pete said some have stock HID which mine does not. It has standard 9006 bulbs in the low and 9005 in the high. So I must have reflector lenses.
Old 12-16-09, 08:59 AM
LuxuryMods
Former Sponsor
LuxuryMods's Avatar
You are correct, however there are 2 types of reflector lenses. Halogen or HID.
So for "proper" lighting modifications, here are your options.
1) Reflector swap - HID reflector into your headlight
This requires you to open up your headlights (I like the oven bake method), and unscrew your Halogen reflector and replace with HID reflector
2) HID Projector Retrofit - HID projector from another HID equipped vehicle into your headlight
This requires you to open up your headlights but this time using your HID projector of choice. Since the GS headlight is HUGE, you have a lot of options! Q45, LS430, LS460, FX-R, S2000, etc. We have special made brackets for Q45, LS430, and FX-R (coming soon) which make this job a breeze.
The costs associated with #1 is of course the cheapest, however for the amount of work you put into doing it, the output will still be "ok" at best.
#2 costs a bit more but by the time you are done, your headlights would blow away anyone with halogen reflectors anytime of the day.
As for color of the bulbs, just pay attention to those colorful HID kits on the road and look at the amount of output it shoots to the ground. It's not much. Kinda cool to look at, but that's about it. Does nothing for you other than make you stand out from the crowd.
Sticking in the color temperature range of 4300k to 6k at most would yield you the best output on the floor and make it easy on your eyes for long driving periods.
Old 12-16-09, 09:32 AM
Neo
The One
Neo's Avatar
^^^ +1 on what LuxuryMods said. I have 6k in mine and the color/output balance is just right. I did adjust mine lower like PHML.
Not the best picture but you can see the white color output. I don't have wall or beam output pics. Sorry.
Old 12-16-09, 11:04 AM
SYNSEI
SYNSEI's Avatar
^^Is that a plug and play kit?
Old 12-16-09, 10:12 PM
Neo
The One
Neo's Avatar
Yes..........
Old 12-17-09, 10:46 AM
fro20
fro20's Avatar
Neo are those HID's in halogen reflectors?
Quick Reply: Gs300 I want HID's but need help!
