I accidentally ran across these adjustable control arms...
I like these front control arms... they seem thinner than our oem arms. Good for guys on Air Bags. Does anyone have these on their GS? Also, running these with front RCA's... Will probably do wonders with front camber issues. Does anyone have these 2 items on their GS is it worth the $$$?
they do make them, in fact they too make EVERYTHING available for the GS. The arms you want run about $800 bucks. just gotta know where to go...
Just one of some spots to look
http://www.l-tunedparts.com/product/...ubmit&x=64&y=6
SPC Camber Salvation!!
Since my Bilstein PSS (fronts only) lowered my front by about 2", I have been wasting away tires like crazy. Started with PZero Neros (which I hate), then moved over to GREAT Bridgestone Potenza RE960AS Pole Position (highly reccomended). Going on my second front sets last week. It really sucks because the outside thread is perfect, another 10-12K miles on them, but the inside were unsafe as they were bald slicks! Need to get these arms in quick so that I can restore normal wear on expensive tires at $225 a pop. I would love to hear if anyone had these installed and how they like them. Would also like to hear about before and after measurements of camber's you guys had out there. Did anyone had to use full +2 degrees for camber, or was that overkill...
Thanks SPC and thanks to you guys ahead of time
LexGS
LexGS
Camber doesnt wear tires at all! There are many people who have their tires at a 45+ degree angles and dont wear, just changes what part of the tire is being worn. Its your toe that is killing your tires. In any event, there is no need to buy anything, you just gotta get an alignment. There are many people with MUCH more of a drop than 2 inches still running stock parts with no wear. I'm running air tucking all my rims all the time and dont get inner tire wear, or rather didnt until I got a bad alignment. In conclusion... when you drop a car, you get negative camber (which isnt bad) and your toes go out (which is real bad) and takes out the inner tire. So instead of your tires facing straight like this:
They are facing like this:
thus dragging the heck out of the tires
go get an alignment
(BTW, Pzeros are THE BEST! I will never look back)
go get an alignment
i asked if figs could come up with some caster arms with heims like the ikeya formula ones. my daizen bushing already split so my shakes are back a little....and Mr jokster is right the toe is the worst on your tires,,,,
