noob needs help: vsc and vsc off lights came on
quick question bout check engine light...
i just got the vsc and vsc off lights on after addin lucas fuel injector cleaner and fillin up my gas tank..i searched it on here and read it was maybe a faulty gas cap so ima go ahead and buy a new one...but then i started wondering why didnt my check engine light come on..can the check engine light be disabled ?? also does it turn on everytime u turn on the car? , or does it only turn on when u have a big problem with the engine ? now i m kinda scared if i got ripped off with this lexus ..
note: just bought my lexus sunday and worried i got scammed
i just got these lights yesterday after i put some lucas fuel injector cleaner in my car..as soon as i turned the car on the lights came on at the gas station..the vsc and vsc off lights came on but no check engine light just those 2 then i stepped on it and it only goes if i punch it hard it just seems like it dont wanna go then picks up and then loses power again..help me out lexus peeps ...
my first lexus and i m having bad luck with it so far
Forum Administrator
Start off by checking your gas cap to see if its on tight.
the vsc changes your driving, check your o2 sensors, mines came on with the vsc and the check engine, turns out it was the o2 sensor. but your check engine didn't come on so yeah idk try it though.
Trying to figure out the same myself...
GO to an AutoZone and have the code pulled that's triggering the CE light. Search the code on here.
Mine's a P1349 if I remember right...I think its my oil control valve. Or its filter, but I may not have a filter on my 400, not sure yet... Digging into mine on Monday.
The plan:
1. Run 1/3 can of Seafoam through the crankcase, drive 50 miles or so and change the oil. Pull the oil control valve and clean it. Pull negative battery cable, eat lunch, and reconnect/drive to see if CE light returns. Should cost me $30. If not fixed...
2. Order an oil filter screen from Lexus (~$8) and replace. Complicated replacement on the 4.0 V8 involving bearing cap removal. If not fixed...
3. Order a new oil control valve ($~120?) for Carson and replace. If not fixed...
4. Dealership.
The plan:
4. Dealership.
The plan:
4. Dealership.
The plan:
4. Dealership.
Lookin for part ..help me out
well i had posted before that i was havin problems with my lexus gs300..well i got it scanned and it said i had p0430 but they cleared it said it prolly came up since i put lucas fuel injector cleaner..and then i got a p1121 code and it makes my car stay on limp mode and goes whenever it feels like it..i have to floor it in order to get it goin on..can someone tell me where i can get this app sensor or whatever its called for a good price i can do the install myself thanx
