Horrible knocking, rough running after cold start, 1+ week in storage
This same issue is coming up in the GX forum with their 2uz v8’s
I have had 7m, 2jz and 1uz motors do this at start up only to clear up in less than 1 min maybe 10 seconds.
My 1998 GS400 beater with over 340k miles does this once or twice a year, especially after being parked a while .
It always clears up and runs perfect.
Nothing scientific just my personal experience with Toyota cylinder heads.
I agree with others that sticking lifter buckets at the valves are the cause; till oil and heat break them loose, then it runs perfect.
I do agree that maybe dirty oil MAY have something to do with this...
Photo taken from https://www.lextreme.com/change-1uzf...er-bucket-sub/
Last edited by FrankT; 02-04-20 at 02:23 PM. Reason: GX470 has a 2uz. Content correction.
02 Lexus GS 300 knocking on cold start and when hard acceleration
I have a 2002 Lexus GS 300 that recently I had to get my exhaust replaced cause it was stopped up and the car wouldn’t go any faster then 25mph. I noticed the sound when it started just going 25 when I was taking it home. Got the exhaust fixed and it’s moved now but it does the knocking now in a cold startup and when I stomp it. My oil levels good. My current codes is random misfire and a o2 sensor. Can’t figure out why I keep getting a random misfire but worried about the knocking sound first. Can anyone help? Any suggestions before I just take it to the shop again? Haven’t taken back to the shop cause I’m in a small town and the shop that put my exhaust on also caused a transmission fluid leak next to the exhaust. Also the car sat for like 2-3 weeks when it was waiting for parts. I would start it but in the process my battery died and my altinator went so I stopped starting it till I got the parts. Once I got them the altinator and exhaust was put on and was still doing that.
Hello everyone,
I have a 2003 GS430, with 71000 miles. During the holidays (and a big East Coast Snow Storm!) I parked my GS430 in my unheated garage, unused for about 8 days. Temps in the garage never fell below about 30 degrees or so - cold, but not THAT cold.
When I started it after it sitting for 8 days, it started right up, but the engine made HORRIBLE knocking sounds and ran VERY roughly for about 30 seconds. After 30 seconds, the knocking gradually disappeared, although a light knocking/tapping sound continued for another 60 seconds or so. I knew the oil was full, and there was NO oil pressure light or Check Engine light, so I let it continue to run. After a couple of minutes, even the light knocking/tapping went away. Never had any lights on the dashboard come on.
It sounded very much like an oil issue. I have owned this car since new, and use Mobil 1 5W-30 EP, with a Mobil 1 filter, which has an anti-drainback valve.
I vaguely remember this happened once before with this car - so this is twice this has happened in 6.5 years of ownership.
After this happened, I changed the oil, since it was due for a change anyway. The oil was not particularly dirty, and I know the engine is clean, as it has used nothing but Mobil 1, changed fairly frequently its entire life.
Was this related to the VVTi? I am a bit surprised that the oil would drain so completely after only 8 days of sitting. The noise really sounded bad - like the engine was self-destructing.
Has anyone had this happen to them? Car runs fine now. Is there anything I need to check? Thanks for any comments...
I had similar a few weeks ago. Same scenario, car had been sitting, cool temp and also high humidity. And, it did the same in cool/cold high humidity once many years ago (I live in a generally dry climate) I think the humidity soaks into the electronics and the car has a brain glitch. Not oil problem.
A knock can be a little tougher to diagnose that a misfire. Usually a misfire is a problem in the ignition system but a misfire is more of a fuel or timing problem. Possible worse like a bearing or rod flopping around.
Keep us updated with all the symptoms and we should be able to narrow down the possible causes.
CallmeQ
GS - 1st Gen (1993-1997)
07-06-09 09:21 AM
