On vacation, keys locked in trunk, Fahhhhh
my trunk was locked when I broke into to my car to pull the trunk release. However I am guessing with the valet key when you unlock to the door it will disarm the alarm?
I believe the trunk release is automatically locked out when the alarm is armed. This way if someone busts in the window, they can't get to the trunk even if the trunk lock is not enabled. At least I think thats how it is, I'll have to try it sometime to double check heh.
Fro, you're better off getting an additional master cut/programmed in this instance. That or possibly teach a certain someone what pockets are designed for.
Big Mack
i actually did this exact same thing on vacation over the summer........ Not sure if you can get them the same way i did, but i have my factory sub removed so i just pulled the speaker cover off and fished them out of the sub hole
i guess you could always take the cover off and then remove the speaker and fish them out with a coat hanger
good luck!
good luck!
