Having some odd issues as of late.
It's been snowing here as of late and after a drive to my work 2 miles away and back. Everything was fine. I parked my car. I had to move it, when I moved it the Speedometer stopped working. I've been using a Garmin GPS wedged into where the speedo is for speed reasons for the last couple of days.
Here's what I got-
-Dead Speedo
-Cruise Control works Fine (Tested with Garmin for speed, Speed remained consistant +/- 1.)
-All MPG information in the Stock Navi is at 0.00 and Mileage to empty is the same since then.
-All functions in the Navi still lock out when the car is in motion
-VSC/ABS/VSC Off lights are on in the vehicle, but we're on prior
Another thing, this has only happened since this happened, on 3-4 occasions, The navigation thinks I'm in some random street in Washington DC and freezes for about 3-4 minutes. Same roads I always drive on, and it claims to not have a GPS signal during such time. All functions that are normally blocked out when the car is moving all function. If I put in an address it will navigate me from whereever in Washington, DC to where I select. Eventually it straightens out, but still is a little slow/jumpy at times.
I would think if the VSS is the culprit...cruise control wouldn't work for one. In our cars do they trigger ABS/VSC/VSC off lights or a CEL?
Here's what I got-
-Dead Speedo
I have pulled the negative battery cable and reset everything to no avail. Also, gas gauges seems overly sensitive on peddle input when getting low. Once the car is below a 1/4 of a tank, if I'm on the gas, it will drop low enough the gas light will flicker on. When I left off the gas, the needle jumps from the E line to a 1/4th tank again. When the car has more than that, its fine. Recent repair work involves upper control arms and the differential was replaced about a month ago.
I keep thinking VSS as well, but the cruise works.
Yeah, I know. The reason why I posted was because when searching I found other people had the issue. People would chime in but they never came back to say how it got fixed or if it did. I was hoping one of those individuals would possibly see the thread and have an answer or maybe someone else would.
Took the car to my dealer (Toyota dealer). They ran codes, came back with 12 codes. They disconnected every wheel sensor and reconnected them. Disconnected the VSS and reconnected. Checked all the wiring. Reset codes. 3 of the codes stayed. Both for front speed sensors and abs control unit. A year or so ago, I fit a front bump HARD with the wheels and it tripped these three lights to come on. So, I'm assuming they those were the 3 codes from back then. Paid 39 bucks for the diagnosis. When I drove the car off the lot, all speedo functions were working fine again. Car was driving completely fine and my mpg was up to about 24ish on the highway, which I haven't seen in a while. I've been getting 17-20mpg since those lights originally came on. Prior to those lights coming on, my car got 23-26 on the highway and 19-22 in the city. Maybe just a coincidence. The sensors are getting replaced and I am anxious to get ABS VSC and traction control back.
I know the service advisor there. That's why. He tends to hook me up on the labor side of things, but in turn I get no free loaner (which they offer). I order all my parts from Sewell and he lets me bring them in.
From what he said, the ABS control code comes on when speed sensors are at fault? Is this true? I just know I've seen people replace abs speed sensors to no avail only to have to end up replacing that later.
I baby my car when I'm looking for those numbers lol. I can drive normal and get the 20-22.5. But I like to make that premium fuel last... lol.
any word on this?
langsdale
06-03-10 09:55 AM
