Disconnect the battery before you do anything or the airbag WILL deploy in your face. There are two screws (one on each side of the steering wheel behind the cover plates) that need to be removed for the airbag to come off. A small flat head screw driver will help with the removal of the plug behind the airbag. PM me if you need any further assistance. Good luck
