Whistling sound only at 39 MPHs???
Old 01-16-10, 12:38 PM
duckJAI
duckJAI's Avatar
I HAD this exact problem and it came from the rear. You would need a passanger to confirm this.
It seemed like it was coming from the diff, and once it was not 40mph, sound was gone. Slowed down to 40mph, sound came back.
It's very distinct and annoying.
I think it's the diff if it's coming from anywhere in the rear.
Have someone sit in the back seats and go up to the front passanger side after and see where it's louder.
Old 01-19-10, 05:54 AM
kphu
kphu's Avatar
Actually, I wouldn't be surprised if its the diff because when I shift from Reverse to D sometimes I get a little bit of a clunk or its feels like a small jolt as oppose to a smooth transition. Is the diff covered by warranty i.e. if I take it to the dealer and ask them about the diff would they charge me for it?
Old 01-19-10, 06:29 AM
duckJAI
duckJAI's Avatar
I'm pretty sure your drivetrain warranty is over if your vehicle is older than a 2005.
They probably would charge you for it to check it out.
Old 01-19-10, 09:17 AM
GS4_Fiend
GS4_Fiend's Avatar
Try turning off the ASL in the audio see if it helps.
Old 01-20-10, 05:47 PM
kphu
kphu's Avatar
Bummer....
I turn of the radio completely so I don't think it would make a difference, but I'll give it a shot.
It now occasionally happens.
Old 02-05-10, 05:52 AM
duckJAI
duckJAI's Avatar
Any update on this?
I got my TRD 1.5way diff inside now and I still get the humming/whistling. Probably not a diff issue since I had it even before with the open diff in the GS300
Old 02-08-10, 10:17 AM
duckJAI
duckJAI's Avatar
I may have found the problem.
I had my mechanic put the car on the hoist to see if we could find the problem, and we did notice the beginning of the driveshaft right after the tranny, where it bolts up it is somewhat loose and can be moved slightly left to right.
That might be causing the problem, not sure if its the same for everyone else though.
blvlboy
ES - 5th Gen (2007-2012)
11-29-18 12:25 PM
Hagar
04-02-18 05:45 PM
sheikhmax
GX - 1st Gen (2003-2009)
18
01-13-17 01:25 PM
JFNash
04-10-12 08:36 AM
tone
11-28-05 05:37 AM
Quick Reply: Whistling sound only at 39 MPHs???
