Lexus Dealership's Diagnotic Results - Does this make sense?
1998 GS400
Reasons for (diagnostic) visit:
- Some smoke in exhaust
- Loosing coolant from somewhere
- (More recently) Check engine light, VSC, and VSC OFF lights on, chugging at idle. P1349 and P1346 codes pulled.
- Valve cover grommets leaking oil into the spark plug cylinders
- Recommended: replace the 8 valve cover grommets (#11193-70010) and both gaskets (#11213-50031 & 11214-50011). $297 installed.
- Pinhole in the bottom of the radiator
- Recommended: replace radiator with Lexus radiator (#16400-46570) or aftermarket radiator. Aftermarket is $465 installed.
I would suggest going and getting some tools.... ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Im sure you can replace your valve cover gasket pretty cheap.... and for the pinhole in the radiator? did they show it to you?? in that case get a radiator and replace it yourself... maybe 200 in parts.... save yourself 565.00
does make sense, but what concerns me is that you have an oil issue AND a coolant issue at the same time...is there any coolant in your oil? Check ASAP, as this could be an indicator to a blown headgasket...
What color is the smoke? Black smoke would indicate that you are burning oil. White smoke would indicate that you are burning water/coolant meaning a head gasket issue.
Change your oil to full synthetic and you will never see blue again ![Big OK](https://www.clublexus.com/forums/images/smilies/bigok.gif)
This will damage you spark plug leads but will not cause smoke from tail pipe
Buy borrow a radiator pressure tester and find leak / second opinion
Thanks for the input, guys! Yeah, I'm thinking I order the parts from Carson and do 'er myself. Any input on a good radiator brand/size that'll fit the GS4 well? Thanks for the offer GSJake! I think I'll take the bumper off and take a look around to see what's all involved. I suppose that would be a good time for a headlight retro, huh?
Smoke is blue. Lexus did a pressure test on the cooling system, that's how they found teh pinhole (I'm told). They said the reason I could be burning oil is that there's a rubber tube somewhere in the valve cover that's shot, letting oil get by, and it would explain why at start-up I see the most smoke. (Granted, it's not a TON of smoke, but some.)
i believe mishimoto makes an aluminum radiator for the gs4...don't quote me though.
As for the rubber tube, idk what they'd be talking about outside of the PCV system...they might be trying to say the PCV is stuck open or something. I'd replace it as it's relatively cheap anyways.
Bocatrip
07-22-16 10:11 AM
gs2impress
GS - 1st Gen (1993-1997)
10-22-10 02:53 PM
