Uneven Tire Wear!
Old 01-18-10, 05:24 PM
GSteg
GSteg's Avatar
Push your car's front end down to see if the shocks are damping the movement at all.
Normally you can feel if you're hitting the bump-stop. It's the point where you've bottomed out and feel a thump of some sort.
Old 01-18-10, 06:47 PM
eyecon7
eyecon7's Avatar
ok will do, to hit the control arms it would need a good amount of pressure right?
Old 01-18-10, 07:11 PM
tom steele
tom steele's Avatar
bad strut is what causes that type of wear or unbalanced tire more than likely the strut though.....
Old 01-19-10, 07:19 AM
eyecon7
eyecon7's Avatar
Its not my coilovers, I kno its not blown.. or the ride would be horrible
Old 02-02-10, 09:09 AM
eyecon7
eyecon7's Avatar
TTT.......
Im gonna replace my castor arm bushing soon. gonna go back in to firestone in like 3 weeks see how off it goes, Lifetime Alignment Is great!
Old 02-02-10, 09:57 AM
kevon54
kevon54's Avatar
Usually some places wont honor lifetime if your car is lowered. You lucked out on that one...
Old 02-02-10, 10:33 AM
jcat_350
jcat_350's Avatar
Originally Posted by eyecon7
TTT.......
you need RCAs. for your tires to be out 3 degrees, no wonder they're wearing uneven.
Old 02-02-10, 11:25 AM
PHML
Master Thread Closer!!
PHML's Avatar
good thing is your toe is within specs now. but those camber numbers need to be fixed.
Old 02-02-10, 11:41 AM
jcat_350
jcat_350's Avatar
I just noticed the note on the bottom of the paper:
left rear toe eccentric will not allow tie rod to move into spec.
translation = rear rca's
Old 02-02-10, 12:49 PM
eyecon7
eyecon7's Avatar
If i put RCA in the Rear? then my Wheels wont fit correct? Im on a credit card status right now. I just want my fronts to not chop. So i was thinking about getting RCA in the front For sure
Old 02-04-10, 01:02 AM
a#'z
a#'z's Avatar
How many miles are on ya cars, so i can know when my struts are dying out, thanks. (yeah i know it depends on the road etc.. you drive, but the average when should it be replace comparing each others average)
Old 02-04-10, 01:12 AM
chrispy
chrispy's Avatar
Just get some aftermarket toe rods to get your toe in spec. Camber doesn't kill your tires, toe does.
Old 02-04-10, 06:15 AM
eyecon7
eyecon7's Avatar
Where can u get those? front and back?
Old 08-02-10, 11:18 AM
eyecon7
eyecon7's Avatar
TTT.. where can i get aftermarket toe rods, for the front?
Old 08-02-10, 12:19 PM
vwynn
vwynn's Avatar
im selling my megan ones if u check the classifieds
Quick Reply: Uneven Tire Wear!
