So ive went threw 2 sets of tires already, I dont mind inner tire wear but the problem is my front tires are getting Chopped up and thats whats been causing
my vibrations and steering shake! my Camber is i think -2.1 in the front,, rears are fine! just some inner tire wear but it smooth! my caster and toe are in spec up front! I dont kno what to do. Im gonna put on the rack later this week to see what everything reads. but I just want the tires to Wear smooth on the inner! BTW its a 225/35/20 on a 20x9.5 car is lowered
What do you mean the tires are chopped? Do you have pictures of the wear? I have practically the same camber angle as you up front and my tires are wearing fine.
if your steering wheel was dead straight in that picture, your toe is certainly way out of spec.
I think in that pic the steering is turned a lil
like camber wear on the inner, but to only half of each section of tread
Originally Posted by ElitistK
are you sure your toe and castor's in spec? if your castor arm bushing is shot, you will never be in spec.
i dunno i got an alightment bout 3 to 4 months back, i never replaced the castor arm bushing, but i have it... im gonna go to firestone, and see what it reads..
Im thinking its bad bushing's i got new ball joints, new tie rods, new control arms, its castor arms balance, but if ure shocks are bad dont it sound like its rattling
when you hit a dip in the highway does the car continue to bounce? or does it just bounce once and settle? If it continually bounces your shocks are gone.
