Video/DVD/TV on stock Nav screen - no problem !!!
Old 06-11-02, 02:57 PM
  #121
jstjohnz
jstjohnz's Avatar
VideoNavi: Excellent info, thanks, more in PM.
Have you made any headway on relocating your dash-mounted CD changer to free up a DIN space in the dash? From what I have seen it doesn't look easy as the changer connects to the tape player/controller with one or two printed ribbon cables.
-jim-
jstjohnz is offline
Old 06-11-02, 05:48 PM
  #122
enginyr
Banned
enginyr's Avatar
Originally posted by VideoNavi
The Pioneer GEX-P7000TV has a on-screen display chip (made by Mitsubishi) that requires a veritcal and horizontal sync. signal from a LCD controller chip. The LCD control chip is only inside a Pioneer screen, like AVD-505, AVD-W6010, AVX-7000, AVX-P7000DVD. These sync. signals come to the GEX thru the front 20 pin RGB connector. So without a Pioneer screen attached you won't get a on-screen text (channel numbers, setup screens and video input labels). Without on-screen text it's impossible to setup the GEX and makes it very difficult to use. To overcome this you can plug in a Pioneer screen to the GEX 20 pin plug, but you then need to hardwire (solder to PCB) 4 wires that will go to your navi display. The Pioneer screen and your navi screen run in parrallel. If using a screen like Pioneer's AVD-W6010 you can then use the GEX's rear composite video output to have the AVD-W6010 display a different source (video and audio) than what is displayed on the navi screen, while still keeping the sync. signals for navi on-screen text.
A difference between using the Pioneer GEX-P7000TV vs. Pioneer AVC-RGB1 (discontinued) is the GEX will do video switching between navigaiton screen/video and it also has TV Tuner, 2 AV inputs, 1 rear AV output, built-in FM modulator. With the AVC-RGB1 it requires you build a switch or switched relay to change between navigaiton and video. As for the Lexus RGB navigation interface it uses .75V P-P RGB + Composite Sync. - same as Pioneer RGB interface. This is why this Pioneer stuff works on Lexus and Honda/Acura navigation displays.
I've modified Pioneer GEX-P7000TV's for people at $120 and that includes a new IR eye for the wireless remote that comes with the GEX. Send me PM if your interested...
Hope this helps...
How much to do my whole setup....This has gotta get done already!
enginyr is offline
Old 06-12-02, 07:52 AM
  #123
Customlexus
Customlexus's Avatar
Default $$$$$$$$
Yeah how much will this cost?
Customlexus is offline
Old 06-12-02, 10:44 AM
  #124
Vld
Vld's Avatar
Angry
Hi everyone,
My "Vlad" account does not work - I can not post reply, post new messages, check my PM. I am very upset because of it. I do not think, I will post a future info in this forum. If somebody interesting in my project please communicate with me via e-mail at Lavinna@attbi.com. I will put all update on my web page.
Status of my project:
Existing problems:
1) Unpredictable behavior of “fuel consumption” measurement circuit during cranking.
(Wrong “fuel gauge” indication on instrument panel and unreal gallon per mileage measurement)
Status – DONE
2) Unstable video synchronization because of incompatibility of GEX sync output and Nav. Input.
(Interlacing effect, flickers…)
Status – DONE
3) Unstable video synchronization of OSD on wide-screen DVDs.
Status – DONE
Features:
1) No internal modifications of GEX required !!!
2) Programmable “TURN ON” delay for video and audio noise free operation (very need feature for some DVD changers)
3) Programmable remote free mode (one button control).
4) Programmable TV auto skip
5) Simple installation procedure
Global project status – going to PRODUCTION
Regards, Vlad
Vld is offline
Old 06-12-02, 10:47 AM
  #125
Static911
Static911's Avatar
Vld,
You can now use your Vlad, same password and everything. Apparently, you forgot to active the account through the email. I just activated you. Weird, the problem just showed up 'cuz typically, you can't post without first being activated. However, you aren't the first person. Some other people on ClubLexus are posting, but never went through the account activation stage too.
Ethan
Static911 is offline
Old 06-12-02, 11:44 AM
  #126
VVT-i
VVT-i's Avatar
Congratulation..Vlad
When can we get this set up. Can't wait.
VVT-i is offline
Old 06-12-02, 11:49 AM
  #127
Vld
Vld's Avatar
Smile
I do not know yet. Working on it.
Regards, Vlad.
Vld is offline
Old 06-12-02, 06:35 PM
  #128
Vlad
Vlad's Avatar
Smile
I got it....
(Infrared remote eye)
Attached Thumbnails Video/DVD/TV on stock Nav screen - no problem !!!-dsc02128.jpg
Vlad is offline
Old 06-14-02, 04:01 PM
  #129
Toog4me
Toog4me's Avatar
where is the infared eye usually stored??? I use those things in my home theatre, but i never thought of it in the car.
Toog4me is offline
Old 06-17-02, 04:47 PM
  #130
Vlad
Vlad's Avatar
Smile
IR location
Attached Thumbnails Video/DVD/TV on stock Nav screen - no problem !!!-picture-009.jpg
Vlad is offline
Old 06-19-02, 11:52 AM
  #131
gazza67
gazza67's Avatar
Default dvd install
vlad brilliant job,have you any experiance of the touch screen fitted as standard to ls430,we are wanting to install a video input into the system.Lexus in the uk say this is not possible,any help would be appreciated
gazza67 is offline
Old 06-20-02, 07:26 PM
  #132
jstjohnz
jstjohnz's Avatar
The Pioneer GEX-P7000TV has a on-screen display chip (made by Mitsubishi) that requires a veritcal and horizontal sync. signal from a LCD controller chip. The LCD control chip is only inside a Pioneer screen, like AVD-505, AVD-W6010, AVX-7000, AVX-P7300DVD. These sync. signals come to the GEX thru the front 20 pin RGB connector.
I have opened up the RGB cable and I believe that the V and H sync signals from the monitor are on YEL and ORG (shielded pair).
Is the BROWN of the BROWN/PINK/VIOLET/GREEN shielded quad the composite sync to the monitor?
I have taken this composite sync signal (BROWN), and run it through an LM1881 sync separator, then use the V and BACK PORCH outputs of the 1881 to feed back to the 7000 on the YEL and ORG, and this does allow on-screen display to work although everything is shifted a bit right (though still readable) as a result of using BACK PORCH instead of 'real' H SYNC.
Where in this cable can I hook in an IR receiver? I'm still not able to run without the monitor attached as the only method I have of controlling the 7000 is via the remote IR receiver on the 6010 display.
-jim-
jstjohnz is offline
Old 06-20-02, 10:42 PM
  #133
Vlad
Vlad's Avatar
LM1881 is not a good choice :-). You do not need BACK PORCH signal at all. It has to be real H. Sync or .... It is very hard, but possible to get a stable synchronization using LM1881. I found much better solution. But it is not just one chip :-(
You can check stability of you OSD on wide-screen DVD or TV without antenna.
P.S.
GEX do not provide a real synchronization. In reality it is composite video signal.
Regards, Vlad.
Attached Thumbnails Video/DVD/TV on stock Nav screen - no problem !!!-dsc02119a.jpg
Vlad is offline
Old 06-21-02, 07:07 AM
  #134
LS007
LS007's Avatar
Vlad,
Great job on tricking the Mitsubishi OSD chip. Can't wait to hear the details of your solution.
Jstjohnz,
An infrared eye that will work with the GEX is Radio Shack 276-0137. It needs +5v, GND and the REMote lead in the 20 pin connector. I connect my remote eye with 1/8" stereo headphone extension cable. I cut the female connector off about 1' back and solder the male wire/connector on the infrared eye. Black is GND, White is +5v and red is the REMote wire. The femal end of the connector I then route the wire through the extra hole on the OSD wire harness and solder directly to the GEX's PCB.
Hope this helps.
LS007 is offline
Old 06-21-02, 09:44 AM
  #135
jstjohnz
jstjohnz's Avatar
I haven't removed the GEX's PC board from the chassis yet, I am just hacking into the RGB cable. Do you know which cable conductors are +5V and IR Remote?
-jim-
Hope this helps.
jstjohnz is offline
Quick Reply: Video/DVD/TV on stock Nav screen - no problem !!!
