Is AutoZone Code Reading Reliable?
Hello All,
My check engine has been on and I decided to go to my local AutoZone since they offer free code reading. Turns out the code being pulled was P0141 for the sensor, but when he printed out my report - every car on the sheet that was read that day pulled the same code?? Maybe I'm just crazy and the report prints out cars that pulled the same code?! But I remember reading articles about places like AAMCO that offer free code readings and tell you that you need some part and they basically scam you for 100 bucks.
In your experiences, is that reading reliable? I'd hate to buy the part if it's not going to help me.
Thanks to all....
Thanks to all....
As long as you have the code, just search on CL and look up the real possibilities as to what is causing the problem. Autozone will give you a list of things that could be wrong associated with the code. When in doubt of the actual codes pulled, get a second opinion, from either another autozone, or another place that scans.
Last week my car had the PO141 code. I went to Aamco and had the code read for free. I searched CL to see what the problem was, ordered an O2 sensor from oxygensensors.com as advised by CL. The sensor was $106 shipped. I searched CL for a DIY install but it was raining here in So Cal so I decided to let the professionals handle it. I searched CL for a reliable mechanic and took my car to Dynamic Auto Service in Midway City. The mechanic charged me $75 to install the sensor. The check engine light is gone...
Thanks CL and the power of the search button...
The thing to watch out for it that some of the self powered scanners (has a battery in it, not just powered by the car's obd port) can hold codes from the last scan and if they don't clear it then it may be giving stored codes, or pending codes from other previous vehicles by accident.
Pay particular attention if you get a scan and they say you have multiple codes.
Some chains are shying away from doing this anymore due to complaints of selling parts that don't fix problems, or erasing important pending codes.
Generally don't buy anything at the moment. Read up on the code before throwing away money on the spot. Lots of things can throw a code refering to a part without the part actually being bad.
OP, you can also ask to borrow the OBd and check the codes on your own. they usually dont want to deal with it anyway and would be happy if you did it on your own. Just seem like an honest guy, i am sure you are, and they should hand it over. If not offer up you ID or something to prove you arent a crack head and going to run with the goods.
