Steering Wheel Shake
Old 01-30-10, 01:55 PM
ChampGS3
ChampGS3's Avatar
This is Definitely a Control/Caster Arm issue.
You can get the 03-05 updated/stronger No.2 LCA's, also known as the Caster Arms, from Lexus of Pembroke Pines 1-888-373-4470. They have the Best prices around. Talk to Dennis and make sure you get the Caster/#2 Arm both Left and Right side part#s, then order online at www.trademotion.com
These bolt on Very easily, you can do it in your driveway, or a mechanic can put these on in 20min if on a rack. You will be very happy with the results.
Don't waste any more time on looking at brakes, lug nuts, wheel weights etc., I am 99% sure those are not your problem.
Good Luck.
Old 01-30-10, 04:56 PM
98GS450
98GS450's Avatar
ive had this problem for awhile as well. I thought it was because of my pads. ill look into it before going out tonight.
Old 01-30-10, 05:35 PM
GSRSRT
GSRSRT's Avatar
My problem is this click noise when i turn the steering wheel idk what that can be, anyone?
Old 01-30-10, 05:40 PM
TruPlaya26
TruPlaya26's Avatar
I had vibrations at one point while braking, and it was due to a slightly warped rotor, took it to my mechanic friend and he cut the rotors to smooth it out a little but i ended getting new rotors to completely solve the problem. it's a good excuse to upgrade rotors/lines
Old 01-30-10, 09:43 PM
shvc1991
shvc1991's Avatar
Took the fall and spent whatever money I had and replaced almost everything besides the brakes rotors, brake pads, and brake fluid. Only getting pulsation from the brake pedal now. Steering wheel shake is nearly gone, but I am positive it's just a tire that's out of balance as it comes at 60 mph and goes at around 75 mph.
I replaced the LBJs, control arms, steering bushing, power steering fluid, tie rods, and I have tires on the way. My current tires are illegal as they have virtually no tread left Once those tires are mounted I'll be getting a balance and alignment. And I also tightened the steering pre-tensioner. Got all of this done yesterday in my driveway and it was ****ing cold.
Old 01-31-10, 09:10 AM
alexly
alexly's Avatar
Check your CV joints, that's usually what clicks if anything's clicking while turning.
Old 01-31-10, 09:19 AM
GSteg
GSteg's Avatar
Are cars aren't front wheel drive. We dont have CV joints up front.
Old 01-31-10, 09:38 AM
sivikvtec
sivikvtec's Avatar
Old 01-31-10, 09:43 AM
shvc1991
shvc1991's Avatar
It's his flux capacitor going haywire.
nuraman00
ES - 6th Gen (2013-2018)
16
05-27-18 12:25 AM
Rowdiggty
06-10-13 11:56 AM
mgude
Suspension and Brakes
15
06-07-10 07:30 AM
kkfoto
05-01-07 04:37 PM
robobbi
ES - 5th Gen (2007-2012)
26
01-23-07 12:51 PM
Quick Reply: Steering Wheel Shake
