Door lock Help needed after install
I just changed my motor on the drivers side for the door lock actuator and now my key does not work manually. Is seems to turn very tightly. Passenger side obviously still works fine so what did I do or not do when I was putting the handle back on after replacement?
The passenger side rear door does not respond to the key fob so I quess that one needs replacement as well.
Any suggestions or diagrams would be greatly appreciated. It sounds like a issue some others have had doing this DIY.
You did not allign it back with the door handle. Take it out, and pay attention when putting it back in.
Doors unlocking with double click on the Fob is fine. Only drivers door opens with one click.
mrcrx28
SC- 1st Gen (1992-2000)
08-04-04 08:17 PM
