Squeaky Sun Visor
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
After doing a search I learned there are a lot of squeaky steering columns out there. I've got a different problem (comparatively minor) - when I bring the sun visor down to secure the sun shade on my windshield it squeaks like a '63 Belvedere (did they make those in '63?).
Anyone have this problem and fix it? I was thinking silicone spray on the inside of the visor, but that would probably evaporate in the Florida sun.
Thanks in advance.
TQM
Thanks in advance.
TQM
its actually from the weather (heat) I believe it makes the plastic maybe swell a little because days when its cooler or earlier in the morning it will not make the annoying squeaking sound. I don't have a solution but will try several things and see what works and post my findings
OK. I tried silicone spray on a paper towel, then rubbed onto the plastic rod. Worked well until the car sat in the sun for a while and back came the squeak.
Next, white lithium grease, as advised.
