Possible Leak
#31
Had the problem today. Did not get a chance to pull the door. I know for a fact water is getting in because my driver side autoloc solenoid was rusted to hell. My pass side is perfectly fine.
I switched them and installed new AVS waterproof solenoids.
Conditions: overnight light rain... temps were in the low 60's
#34
https://www.clublexus.com/forums/gs-...eavy-rain.html
#37
Mine hasn't done it since that one incident. Maybe its a molding around the bottom of the window that lets water in. I know when I had my window down at the drive thru for a brief moment during that heavy rain that's when it started up. I never roll down my windows in the rain anymore and I never have the problem. I also looked into the case file for my car and it is indeed the original windshield. Never replaced.
#40
My GS400 car has tantrums when it rains also...I think it’s all the water coming down the windshield and some of that water leaks under windshields and specially though corners that’s causing water to penetrate wiring under the dash.. that’s the culprit in my opinion that’s messing with our electrical system. It’s not big deal in my case because it barely rains in socal….in any case let us know if someone figures this out.
#41
Nah there were lots of other things that bothered me and that no door handle thing is a pain in the *** for a daily. He seems to like it so
He said he's going to get the windshield done again most likely at the dealer. I told him to let me know if it fixes the problem.
Problems with the car that recently happened:
-rack and pinion needed replacing
-front suspension still causing issues
-front rotors warped
-vibration even after changing parts and replacing bushings
-Steering rack bushing needed replacing
-horrible mpg (9mpg) even after fuel treatment and replace plugs also got alignment done
Should i go on?
Meanwhile I picked up one of these pretty cheap, but made sure there was no fixing involved and its got door handles!
Should i go on?
![](https://hphotos-snc3.fbcdn.net/hs508.snc3/26679_514433941102_300100074_449525_1694691_n.jpg)
#42
bringing a thread back from the dead.
a couple days of heavy rain, and i got the same problem.
i noticed today my door locks didnt work after work. then i noticed just now my foot well lights dont turn on, my center dome light doesnt turn on. windows dont roll down via the driver front main control. and the strangest thing, thing ive wanted for, for the longest time, my climate control to display in celcius, but guess what, my blower doesnt work! seems like catestrophic failure!
for now, im reseting the ecu, hope that fixes something.
i pulled a bunch of fuses out to check for blown fuses, but nothing.
#43
since i dynamatted my doors, this has NEVER happened to me since. so something def was leaking either through the doors onto the door ecus or from the windshield that was replaced but since i did nothing to the windshield i would say its 99.9% coming from the doors, ALTHOUGH my carpet was replaced with OEM carpet so maybe they moved something when installing it and the place it was leaking on doesnt hit there anymore. i dunno.i never did notice any rust or anything when i dynamatted my doors so i dunno where it is coming from
per the other thread i see letting it dry out fixed it so you have a leak also....wait till it rains and then freezes, i had to take my car into my heated warehouse and let it "thaw" out before it would work again
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
#45
it seems to be....i was wondering why if i NEVER did anything to the dash it might not be leaking anymore but now its starting to make sense. when that chunk of concrete punched a hole in my floor and they had to reweld my floorboard i wonder if the added insulation they did underneath my car plugged a hole that could have possibly been letting water in.....either way no more issues for me since doing those, or knock on wood no issues to date
