OEM NON-HID to OEM HID:
Hi all,
I have a 2000 GS 300 with halogen headlights and bought a set of OEM GS HID headlights. I'm going to get a HID kit, what type of bulbs do I need and also how complicated is the re-wire from my halogen plugs to the OEM Hid type bulb plug?
Thanks in advance......
you will not be able to use the oem autoleveling feature on the hid assembly, so your best bet is to actually swap the HID bowl onto your non-hid assembly.
As for wiring, if you're going with a legit d2r bulb, you will need one of these:
if you're going with aftermarket bulbs, then the kit should be plug and play with your oem wiring.
roguenode
General Classifieds
11-02-04 10:59 AM
