new key...flip style
#184
Thanks!
If you got it from nycauto parts just email the guy, seems like they have pretty good customer service.
.... Inside your current remote you will need to take the transponder out and swap it into the one you get from nycauto parts, then get it cut.
#185
so ill probably end up getting it cut first then swap it over. does anyone have pictures of the process??? or a DIY on how to take the key apart??? i know theres a spring that i need to worry about...
also how much does it cost for a new key like our regular keys...i only have one key for my gs and i want 2...
#190
the locksmith that did mine cut the key down first with a hack saw. then he cut the key grooves. then i moved the guts over to the new case. also, they didn't take the blade out to cut the key. he just flipped the key blade to the open position and then he put it in his cutting machine as is. he never opened the case i was the only one who did.
#194
got mine, got mine cut, swapped over the guts inside (which looks like a flat square). will try in a bit to see if it works.
the only issue i have is the chrome part on the bottom where the key ring would loop through, mine seperates into 2 pieces, and 1 keeps falling out.
other than that, seems ok, the cut went ok, will see how things go.
