Empty Gas Tank at 1/4 Marking??
This just happened to me last month, after running out of gas driving 150 miles North....Thank goodness for AAA Gold, they came out and gave me 3 gallons of gas. Car started right up...What gives?
So I bought a one gallon red gas container so that I could test this out again without getting stuck... Ran out of gas again, and yep there it is again 1/4 marking, letting me know that I should have 1/4 tank of gas left, NOT. Looks like my 1/4 marking has transformed itself into EMPTY MARKING. Has anyone had this happened to them, what was the issue, what part is failing, could it by a bad float in the gas tank?
Thanks ahead of time...
LexGS
LexGS
The assumption would be that I would need to drop my tank in order to check the floater, right? Can the floater itself be replaced if it is not working correctly or is it a part of fuel pump. I ask since I have never seen the inside of a GS300 gas tank. Back in the old days, I fixed my old 300ZX when it suffered the same issue.
Thank you for the quick reply
LexGS
LexGS
floater is attached to the fuel pump assembly.
to access the fuel pump assembly, u remove the rear seat bench, and its located under the rear driver side seat
LexGS
LexGS
