Timing Belt
Here is my parts list for the 90k/6yr. service
Water Pump
Waterpump Gasket
Waterpump O-ring
Waterpump Rear Pipe Gasket
Front Main Seal
Camshaft Oil Seals x 2 pieces
Acessory Belt
Thermostat
Thermostat O-ring
Timing Belt Idler
Timing Belt
Timing Belt Tensioner
Valve Cover Gasket INTAKE VVTI SIDE
Valve Cover Gasket EXHAUST SIDE
VVTi Pulley Front Seal
VVTi Actuator Filter Screen
Spark Plugs NGK Iridiums
Water Pump
Waterpump Gasket
Waterpump O-ring
Front Main Seal
Acessory Belt
Thermostat
Thermostat O-ring
Timing Belt Idler
Timing Belt
I found this: http://www.rockauto.com/catalog/x,ca...,parttype,5759
Will this do?
Also, are these good?
http://www.l-tunedparts.com/product/?id=1779
Thanks
I use AISIN Part # TKT001 from Rock Auto, all OEM parts it includes :
AISIN Water Pump
Koyo Idler Bearing
Koyo Tensioner Bearing
Mitsuboshi Timing Belt
Water Pump Gaskets & O-Rings
Plus the Tensioner, from Rock Auto, GATES Part # T43097 which is made by NTN, also OEM
I may also have a front crankshaft oil seal on hand. Just in case it needs replacing.
Good luck
AISIN Water Pump
Koyo Idler Bearing
Good luck
AISIN Water Pump
Koyo Idler Bearing
These parts are also for the gs400 correct?
AISIN Water Pump
Koyo Idler Bearing
AISIN Water Pump
Koyo Idler Bearing
Good luck
AISIN Water Pump
Koyo Idler Bearing
Good luck
