View Poll Results: Are you interested in clear lense for the stock fog lights?
Voters: 118. You may not vote on this poll
Fog Light Modifications Lense
only problem with this mod is putting the clear lense on the fog without doing a projector in there. The fluted lense is made to create the beam pattern becasue as we could all see the reflector is smooth. If the reflector created the beam pattern, jike in the head lamps then a clear lense would be fine.
Just my .02 and great if you are doing the projector retro, but probably make fogs useless with that OEM smooth reflector.
Jeremy
Jeremy
Jeremy
Jeremy
But bumping this back up to the top.
What you want to do is remove the the fog light housing. It's held in by 2 phillips head screws. Then once you get those out, you're going to slide the entire housing towards the center of the car. You will then be able to pull the housing out. Now remove the bulb and either let it sit in the sun with the lens down on a cloth so you don't scratch it or take a blow drier to it.
GS Fog Light Projector 3K 35 Watt NO lense
GS Fog Light Projector 3K 35 Watt NO lense Cutoff closeup
![](http://img.photobucket.com/albums/v296/Spyder78/Lexus%20GS%20Foglights/GSFogLightProjector3K35WattNOlenseC.jpg)
GS Fog Light Projector 3K 35 Watt With lense
![](http://img.photobucket.com/albums/v296/Spyder78/Lexus%20GS%20Foglights/GSFogLightProjector3K35WattWithl-1.jpg)
GS Fog Light Projector 3K 35 Watt With lens Cutoff Closeup
![](http://img.photobucket.com/albums/v296/Spyder78/Lexus%20GS%20Foglights/GSFogLightProjector3K35WattWithlens.jpg)
GS Fog Light Projector 3K 55 Watt NO lense
![](http://img.photobucket.com/albums/v296/Spyder78/Lexus%20GS%20Foglights/GSFogLightProjector3K55WattNOlense.jpg)
GS Fog Light Projector 3K 55 Watt NO lense Cutoff Closeup
![](http://img.photobucket.com/albums/v296/Spyder78/Lexus%20GS%20Foglights/GSFogLightProjector3K55WattNOlenseC.jpg)
GS Fog Light Projector 3K 55 Watt With lense cutoff
![](http://img.photobucket.com/albums/v296/Spyder78/Lexus%20GS%20Foglights/GSFogLightProjector3K55WattWithl-1.jpg)
GS Fog Light Projector 3K 55 Watt With lense cutoff Closeup
![](http://img.photobucket.com/albums/v296/Spyder78/Lexus%20GS%20Foglights/GSFogLightProjector3K35WattNOlense.jpg)
![](http://img.photobucket.com/albums/v296/Spyder78/Lexus%20GS%20Foglights/GSFogLightProjector3K55WattWithlens.jpg)
GS Fog Light Projector 6K 35 Watt NO lense
![](http://img.photobucket.com/albums/v296/Spyder78/Lexus%20GS%20Foglights/GSFogLightProjector6K35WattNOlense.jpg)
GS Fog Light Projector 6K 35 Watt NO lense Cutoff Closeup
![](http://img.photobucket.com/albums/v296/Spyder78/Lexus%20GS%20Foglights/GSFogLightProjector6K35WattNOlenseC.jpg)
GS Fog Light Projector 6K 35 Watt With lense
![](http://img.photobucket.com/albums/v296/Spyder78/Lexus%20GS%20Foglights/GSFogLightProjector6K35WattWithl-1.jpg)
GS Fog Light Projector 6K 35 Watt With Lens cutoff closeup
![](http://img.photobucket.com/albums/v296/Spyder78/Lexus%20GS%20Foglights/GSFogLightProjector6K35WattWithLens.jpg)
GS Fog Light Projector 6K 55 Watt NO lense
![](http://img.photobucket.com/albums/v296/Spyder78/Lexus%20GS%20Foglights/GSFogLightProjector6K55WattNOlense.jpg)
GS Fog Light Projector 6K 55 Watt NO lense Cutoff
![](http://img.photobucket.com/albums/v296/Spyder78/Lexus%20GS%20Foglights/GSFogLightProjector6K55WattNOlen-1.jpg)
GS Fog Light Projector 6K 55 Watt NO lense Cutoff Closeup
![](http://img.photobucket.com/albums/v296/Spyder78/Lexus%20GS%20Foglights/GSFogLightProjector6K55WattNOlenseC.jpg)
GS Fog Light Projector 6K 55 Watt With lense
![](http://img.photobucket.com/albums/v296/Spyder78/Lexus%20GS%20Foglights/GSFogLightProjector6K55WattWithl-1.jpg)
GS Fog Light Projector 6K 55 Watt With Lense cutoff
![](http://img.photobucket.com/albums/v296/Spyder78/Lexus%20GS%20Foglights/GSFogLightProjector6K55WattWithLens.jpg)
