5mm is the most on stock studs. i got about 6 turns of the lugnut before it stopped.
i suggest putting longer studs in. u should get the longest they have, in case u wanna go bigger spacer later on.
i just did all 4 corners on mine and its really easy
I would say dangerous. Imagine how much weight the each wheel has to carry and apply the physics on turns etc... Plus, you'll notice that these nuts do not actually lock.
I think there are a few threads for this so you may want to do a search. Otherwise, you can just buy spacers with new studs already built in. This is what I'm running. 15mm front/20 mm rear Ichiba v2 spacers with built-in studs.
