Is this common???
Is this common???
About two weeks ago my check engine light came on in my gs300 so i went to autozone, and it said i had a bad o2 sensor (bank1-sensor2). So i order one off of oxygensensors.com part number (234-4626) so when it came in i replaced it and unplugged my battery etc. I drive to work that night no check engine light on so i thought cool everthing is good. When i leave work and start driving check engine light comes back on, so im thinking WTF. Go to autozone and it says i have a bad o2 sensor again except bank2- sensor2.
My question is, is this common for a gs to have them go bad one after another? Because these lil *****es aint cheap lol
Be easy im a NEWB!!!
i know nothing bout the gs300 so my comment isnt bout that, what part of tn u in?
http://www.obd-codes.com/
If it is your 02 sensor, they do tend to fail at same times but not this close together. My guess is that the autozone steered you wrong
You be easy..lol
Ok i will go somewhere to see what codes are being thrown, and then i will go to this site and see.
If they do normally fail at the sametime what is the normal time span between them or do you have to consider the mileage also???
If you have a stock setup (no fancy air intakes, etc) I would expect a 80-130k miles from a set of sensors
ok the code is a 161
TD- Oxygen O2 Sensor Circuit Low Voltage (Bank 2, Sensor 2)
What it means-
It basically means the PCM detected either an excessive current draw, or an open or short in the circuit powering the oxygen sensor's heater circuit. This is in reference to the Heated Oxygen Sensor (2) located rear of catalytic converter (Bank 2).
lol but im still a lil confused
What it means-
