need help with tail lights!!
hey guys, im newbie to lexus and ran to some problems with my 2000 lexus gs300. let me start fromth beggining and if anyone can help with anything it would be great.
i bougt the ebay LED tail lights know cheap but trying to save lately . i installedthe first one and everything was working, brake lights turn signals etc. after i installed the second one everything in the rear stopped working even the license plate lights stop working but the strange thing is that when i press brake the lights work and the lcense plate lights come on too and when i let the brake go the rear end is pitch black. checked all the fuses ll ofthem are fine. so i took out the led tail lights and put the stock ones and its still with the same problem
have anyone had this kind of problem ??
or does anyone kno what icould of burned or messed up in the car?
please help and if i need better explonation let me know
thanks alot
thanks alot
Its been said but check fuse again and double check all your bulbs as well. If you remove the carpet on the side of the trunk you will find the lamp sensor. I think its one per side.
I had same problem with aftermarket LED tails. The cost to fix was over $1000 at the dealer. Swear to go OEM never LEDs again. GL to you and everyone.
thyshallsm
GS - 1st Gen (1993-1997)
10-30-14 05:03 PM
