Timing belt replacement specialty tools???
I have a 2000 GS300 that I need to replace the timing belt on. Not a big deal for me to do but I found out that two specialty tools are needed for the job. Those tools being a crankshaft pulley holder and a flange holding tool. Does anybody know if these two tools are absolutely necessary or can I improvise with something else?
Thanks in advance
Thanks in advance
you need a crank pulley puller. i ended up using a 8-10in 3 prong puller.
and a crank pulley holder. basically wedged something on the crank pulley, gunned on what i could (under 100ft lbs), then torque wrenched what i could, then headed to a toyota dealership to get them to torque the rest (paid the tech 30 bucks)
I appreciate both responses. Do I need the part specific tool to hold the crank pulley in place or can I use a chain style holder. Also, will a regular pulley extractor work or will I need the part specific tool?
For the harmonic balancer, I used the Alltrade kit. It was a real help, my balancer would have never come off without it.
