Carson only place to get JDM double-din dash kit?
#63
get your brackets and flush mount it... all eclipse deck sit a little far out.
I flush mounted mine and it works great. Just be prepared to keep your wires clean and you have enough room to route it. Not too much room in the back once you slide it flush with the faceplate.
Most motorized 2DIN head units are not flush mount. I'm most likely going to pick up the AVN6620 from Eclipse, unless they come out with a new model soon. But with the idea of just drilling new holes it just opened up my options
#66
I installed my buddy's avn6620 and did a flush mount too. Same way as mine. Drilled at the dimple and used only 2 screws per side for mounting. It is strong enough and is a very simple mod.
#67
Guys, I need to get info on matching the Climate Controls paint
I had one of the $3 air freshner leak oil onto the climate controls and the paint just bubbled off. Crazy!
What paint (this dark gray) can I use to touch up. I thought this might be the right thread since the first page says the guy was able to mach the AC controls color with the Black Double din Kit. but he dosn't recall what paint he used.
This is horrible. Worse case senario I'm going to have to find a used AC controls from the junk yard.
Again any help with how to match AC control color, paint numbers and paint used would be great.
Thanks in advance.
I guess I can stop by an autobody shop and ask if they can do anythign to mix up some matching touch up paint.
Looking for this color.
Thanks in advance.
#68
Thanks in advance.
Thanks in advance.
I finally got my HU in last weekend, flush mounted by drilling the dimples like others have done, came out looking great! Definitely the way to go.
#70
#73
Here's a couple pics, I didn't clean anything up before these pics and still haven't settled on a color for the screen but I'm really liking this thing so far.
Here's one to show how the unit sits in the dash kit.
Couple more.
Couple more.
