HID's in the fog lamps? Too hot or not?
Old 03-13-10, 01:19 AM
  #31
sam430
sam430's Avatar
Originally Posted by GCOP
I would have to disagree. 35watt vs. 55 watt only produces about 1.5 amps of current draw more. At idle thats about 4-4.5 amps, still way less than a 55 watt halohen which at 12 VDC is about 6 amps of current. I own a compnay called HID Mobile here in Houston, we do 55 watt kits in all kinds of stuff, no problems.....
heres my pic
The full power is just used for igniting... it uses less than halogen once lit.
Old 03-13-10, 02:05 AM
  #32
VNN326
VNN326's Avatar
hid's do not get hot as a regular bulb.
Old 03-13-10, 06:05 AM
  #33
shvc1991
shvc1991's Avatar
heres my pic
Very nice looking fogs there. What color temp?
and can anyone tell me how much brighter a 55 watt kit is compared to a 35 watt? Thank you.
Old 03-13-10, 07:09 AM
  #34
lexusscturbo
lexusscturbo's Avatar
It's about 20% brighter so a 4300k would look more like a 3600k almost (yellow but a slight white)
Old 03-13-10, 07:15 AM
  #35
biggieTX
biggieTX's Avatar
I have a noob question. Is the lens in my fogs yellow or is the bulb?
Old 03-13-10, 07:18 AM
  #36
lexusscturbo
If your car has factory xenon's then you have a yellow glass condom which you can break with a screwdriver
Old 03-13-10, 07:28 AM
  #37
biggieTX
biggieTX's Avatar
I assume it is sealed for my protection.
Old 03-13-10, 07:38 AM
  #38
shvc1991
shvc1991's Avatar
^ It's just a plastic capsule that the bulb sits in. It won't affect how the bulb sits in the socket. Just take the fog light housing out and crack the capsule into small pieces and shake/pull them out with needle nose pliers or something.
Old 03-13-10, 12:52 PM
  #39
biggieTX
biggieTX's Avatar
The words "break into little pieces" scares me a bit.... What exactly am I breaking?
Old 03-13-10, 02:48 PM
  #40
shvc1991
shvc1991's Avatar
It's just the yellow plastic piece that surrounds the bulb. Don't worry so much. Haha.
It's the same deal to clear out the amber in the turn signals inside the headlights, unless you want to take the entire headlight apart.
A lot of people have done it. Nothing to be afraid of.
Old 03-13-10, 04:07 PM
  #41
Kyle Harty
Kyle Harty's Avatar
Your other option would be to buy a pair of clear fogs (the GS's with factory halogens have fogs without the yellow sleeve) and sell your yellow fogs.
Breaking that sleeve isn't as bad as it sounds, pop your foglight out and remove the bulb then take a look at it. You can see the yellow sleeve clearly then. You can take a screwdriver and break it through the bulb hole, not hard but I can understand why you'd be hesitant.
Old 03-15-10, 08:50 PM
  #42
TopRamen
TopRamen's Avatar
yea, get some hid's in your fogs and heads. makes a huge difference. i don't know about all those expensive kits though... i run a japanese in the heads and a china in the fogs and they both work fine and are pretty darn similar.
Old 03-15-10, 08:52 PM
  #43
AYEmike
AYEmike's Avatar
Please don't break the yellow capsule inside of your foglights of you have them, its such a waste; plus MANY people would trade/pay for them. the yellow capsule makes a huge difference when you want the "pissed yellow" brightness. But i honestly think the clear foglights with 6k HIDs look more classy, more luxurious than yellow. imho.
Old 03-16-10, 02:23 PM
  #44
sakataj
sakataj's Avatar
i would buy your right one
Old 03-16-10, 06:31 PM
  #45
biggieTX
biggieTX's Avatar
do they make pure white HID replacements for the driving/brights? I think that would add a lot to the look.
Quick Reply: HID's in the fog lamps? Too hot or not?
