Water Damage Car probably totalled. I need opinions
So here goes,
I have a 2002 gs430. I've posted pictures of it before. But anyway, back in January i drove through an intersection that was a little to flooded to drive through. Long story short, it cracked my veilside rear bumper and my wise front bumper. The veilside is definitely repairable but the wise ummmm would need a lot of repair. Also the car got little nicks on the sides. So basically will need an entire repaint minus the roof and trunk. Oh yeah also slightly damaged my rmm grill and pushed it up onto the hood causing little scratches but deep enough to also need a repaint.
Now for the really bad,
engine sucked in water. I was just told by the lexus dealership that I will need a new engine. Price====9k installed
Now my insurance priced it out at 15,500. And the adjuster said if it goes over 80percent of the value then they will be totaling the car. Also the lexus dealership said the engine will be around 9k.
What would you guys recommend I do about the engine. Also will a sc430 engine fit in there? I have found quite a few of those for a fairly cheap price.
Also, everything else electrical still worked fine. I actually made it through the intersection so even though it did sit in a bit of running water, it was only about a foot high. I dont think anything electrical was damaged.
So any advice on how to deal with this? Im thinking if it is totaled, i will buy the vehicle back and drop an engine into it. The car has not been in any accidents so I know it has no frame damage whatsover. Not to mention over 10k in parts/stereo equipment still in it.
How did you get water into the engine if it was only a foot of water? The car has a clearance of about 6 inches, a bit less if lowered, but it's at least 4 inches off the ground. The intake for the engine is on the top unless you're running a cold air intake that is shot down toward the bottom.
I'm pretty sure an SC430 engine would fit, since it's still a 3UZFE.
Big Mack
Big Mack
Big Mack
Big Mack
Does anyone know where i could find out if the sc430 engine harness is compatible with mine. The sc430 engines seem to be a lot more common and about 1k cheaper.
Actually water i drove through was approx 2 ft of water. The intake is right where the grill is and all of the water splashed in there (almost like a little mini wave). I said i was sitting in about 1 ft of water after i crossed the intersection and the motor shut off.
If totaled, get rid of it and get something else.
E55 is what I'd get.
Also I still have an rmm supercharger for my gs430 that has not been installed.
hey dude it happen to my gs4xx today too well not really i was drivig to work and it was raining pretty hard, so ther was a little flood but not really so i try to pass by but run on some of the water and my check engine TURN ON!! and i use K&N intake,(its not cold air) can it damage the engine???
