Recommended oil for 2000 Lexus GS3
Old 03-12-10, 06:36 PM
NVTHSLEX
NVTHSLEX's Avatar
AMSOIL or Mobil 1 fully synthetic
Old 03-12-10, 08:00 PM
j stuff
j stuff's Avatar
am i the only one using toyota 5w30? :facepalm:
Old 11-17-18, 07:30 AM
realtree
realtree's Avatar
Default Gs. 300 oil type
was wondering my lexus has 260k miles wat shound i use synthetic, synthetic blend or conventional im new to lexus
Old 11-17-18, 07:45 PM
SaiyanGS3
SaiyanGS3's Avatar
OBVIOUSLY use whatever got it to 260k!
DarthBacon (12-20-18)
Old 11-18-18, 12:16 AM
TW99GS300
TW99GS300's Avatar
Oil selection will need to concern 2 most important factors. Bearing clearance and temperature.
With stock bearing clearance then it is recommended to stay with factory recommendations. However, over time the bearing may see some wear and could benefit from thicker oil, like 5-30 to a 5-40.
The first number in the oil is the viscosity when the oil is cold. Generally, if your local climate drops to freezing then you will want to stay at a 5 weight.
There are other factors, like oil pressure and leaking seals. But that's a topic to be discussed only if you are seeing leaks and or other symptoms.
Old 11-18-18, 08:37 AM
realtree
realtree's Avatar
Default And how about synthetic synthetic blend
What about conventional or synthetic whats better my uncle told me go to like 10-30 on conventional im questiolqble on it
User 122922 (09-21-21)
Old 11-19-18, 02:01 AM
TW99GS300
TW99GS300's Avatar
Synthetics will maintain it's chemical properties much better than conventional.
Old 11-19-18, 05:40 AM
captainva
captainva's Avatar
Synthetics also have smaller molecules than conventional so they're better at getting into the tiny spaces of your engine and carrying away the dirt and sludge. I would run a high mileage oil like mobile 1 extended performance and don't buy into long duration oil changes. Oil is cheap so change it every 5-7k if using synthetic and that will ensure your engine lasts a long time. Also don't buy low quality cheap filters like the orange Fram
Lestoyota1
05-09-19 04:45 AM
J$mooth23
Performance
13
03-01-16 07:56 PM
newgs3
10-07-09 07:34 AM
chuckb
01-04-05 12:30 PM
Intellexual
Maintenance
04-10-02 08:20 PM
Quick Reply: Recommended oil for 2000 Lexus GS3
