Will an aftermarket car alarm and keyless entry fix door locks
my door locks are showing some strange behavior. Locks will sometimes work and not work. They definitely all unlock when I turn off the car. However, pushing the lock button on the door or remote is not always successful on unlocking or locking. I was wondering if I installed an after market car alarm with keyless entry.....will this fix that problem?
the motors CAN be repaired and do provide a cheap fix, even though sometimes its temporary because other parts wearing on the actuator assembly are what cause the motor to burn out...so its bound to happen again if you dont go with replacing the whole unit..
if you DO buy the whole actuator assembly, one of the most reasonable prices you're going to find is from a forum sponsor of ours (Carson Toyota) and its still a couple hundred bucks, plus install if you're not brave enough to do it yourself.
if you can, find one used for as cheap as possible in good working condition. its a gamble regardless.. lexus never recalled these even those they've been failing in gs's since 98 and still do right up through the 05 model in all trim levels...which means even if you do buy that brand new one for whatever couple hundred bucks it is, it still has a chance to break just as much as the next used one because the design wasn't ever changed.
ive heard there's a different actuator setup or motor that's "stronger" that you can swap in from a different toyota and the parts match up..but i dont have any info on it, try a search.
2GS4Jay
02-22-10 04:04 PM
BigWaveSC
05-29-06 04:02 AM
