Will 235/55/17 Rub on my GS400?
maybe this will help, assuming you are at one of the current oem tire sizes (235/45/17).... not sure why youd want to, maybe you have some free tires laying around..
http://www.willtheyfit.com/index.php...&Submit=Submit
"Old/New
Diameter 643.3mm 690.3mm
Circumference 2021mm 2168.6mm
Poke 63.6mm 63.6mm
Inset 139.6mm 139.6mm
Speedo error 0% -6.81%
Reading at 30mph 30mph 27.96mph
Reading at 60mph 60mph 55.91mph
Ride height gain 0mm 23.5mm
Arch gap loss 0mm 23.5mm"
"Old/New
Poke 63.6mm 63.6mm
Those are way too big. and will rub and raise the height of your car. I wouldn't go larger than 235/50R17. The factory overall diameter on 16" is 26.15 and the factory overall diameter is on the 17" is 25.33.
215/60R16 = 26.16
235/45R17 = 25.33
235/50R17 = 26.25
235/55R17 = 27.18
215/60R16 = 26.16
235/45R17 = 25.33
235/50R17 = 26.25
235/55R17 = 27.18
when i had my 17 stockies. I had the same set of tires. That **** would use to rub my fender daily. I was drop low too. Finally, im getting my fenders rolled and pull this weekend and put on the new set of rims and drop it till it's flushhhhhhhhh.
