looks like Infiniti wheels fit the GS, anyone run the Infiniti sized tires too?
Stock GS400 17" tires are 235/45-17... stock G35 18" tires are 225/50-18 front and 245/45-18 rear... Has anyone just straight swapped on Infiniti wheels with this tire size?
It would be a ~26.75" diameter vs. the lexus 25.32" diameter, which throws a warning on the tire calcuation site, but just was curious how it worked or if anyone had tried it.
Maybe I can help shed some light on the subject, I actually work at 1010tires. It is true you should stay within 3% on factory spec when it comes to tire up/down sizing. However, the factory 16" is 26.16 in diameter where as the OEM 17's are 25.32, that's already over 3% difference in height which not very common. Your overall height on the new tires are only 2% more than the OEM 16's, but on the other hand you are almost 6% more than the OEM 17's. With that being said, I would definitely downsize to a 225/45R18 in the front and 245/40R18 or 255/40R18 in the rear. GL![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
Who in the right mind would put effin INFINITI wheels on a [richard hammond]LEEEEEEEXUS [/richard hammond]
[IMG]
[/IMG]
![](http://i165.photobucket.com/albums/u73/Coco-bun/Lexus/5416b5df.jpg)
![](http://i165.photobucket.com/albums/u73/Coco-bun/Lexus/18f81654.jpg)
^listen to this guy. the pics above are 225/45/18 245/40/18. zero issues...except the front rubbed a bit after I decided to lower my HKS hipermax all the way AND put some RCA blocks. haha.
[IMG]
![](http://i165.photobucket.com/albums/u73/Coco-bun/Lexus/608920f9.jpg)
Answer
06-27-15 12:34 PM
