removing Daizen bushings
Old 03-14-10, 09:11 PM
vwynn
vwynn's Avatar
Default removing Daizen bushings
Ok so first things first.. my newly acquired GS4 (Cinnabar.black) pulls to the right according to the prev owner.. n yea it does pull right.
Now he said the lower control arm could be bent and i was wondering how hard would it be to
A). Remove the lower control arm...
B). Remove the Daizen bushings on the LCA
Im also wondering what if the LCA isnt bent what could it be? He said the alignment is fine and said Todd from TM checked it out n said it was fine. The car hit the curb hard i guess n so now it pulls right.
any ideas?
Old 03-14-10, 09:18 PM
GSteg
GSteg's Avatar
Removing the lower control arm No.1 is easy. Removing the bushing that's attached to it is also easy. The only bushing that's going to be tough to remove is the caster bushing. I'd say its pretty much impossible to remove it without damaging the lip of the bushing.
Old 03-14-10, 11:50 PM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
Still seems like a alignment issue if its trailing to one side or a bent control arm..
Old 03-15-10, 12:16 AM
vwynn
vwynn's Avatar
it goes straight when i hold the wheel center.. but when i left go the wheel turns right n the car goes right on its own :[... also it bump steers a lot and tramlines...
Henry: is the caster bushing connected to the LCA?
Old 03-15-10, 12:24 AM
vwynn
vwynn's Avatar
oh yea ide like to add.. the prev owner pointed out that the front pass wheel isnt perfectly centered compared to the driver side wheel.. its more pushed closer to the door (not noticeable really)
Old 03-15-10, 01:27 AM
VNN326
VNN326's Avatar
seems like you brought a lemon.
grindin8o8
Suspension and Brakes
15
01-30-19 05:46 AM
tedsterb
02-02-16 10:31 PM
Tremander
11-01-15 12:09 PM
bcorey
01-22-13 02:44 AM
JAB
RX - 1st Gen (1999-2003)
11-07-08 10:53 AM
Quick Reply: removing Daizen bushings
