Thanks to all the "Drifters" i screw'd up my Car!
Old 06-02-02, 11:41 PM
  #31
futuregs
futuregs's Avatar
um, a controlled slide.
Old 06-03-02, 01:45 AM
  #32
gs300
gs300's Avatar
Default initial d
anyone ever see or heard of initial d its a very good japanese animated cartoon about drifting
Old 06-03-02, 01:47 AM
  #33
meZoom!
Super Moderator
meZoom!'s Avatar
Default Re: initial d
yes i have initial d in my hand right now. im on 22. initial d is regarded as pretty much the car lovers bible in japan
Old 06-03-02, 02:03 AM
  #34
GlobeCLK
GlobeCLK's Avatar
Default Re: Re: initial d
I'm on 23
Old 06-03-02, 04:16 AM
  #35
GS400_PUSHER
GS400_PUSHER's Avatar
Well Lets hope your rim is not bent....just a little!!! Leave that to the PROs!!!
Old 06-03-02, 04:19 AM
  #36
LexusRules
LexusRules's Avatar
i've seen 'em all they are great.
thank you finally someone that knows the difference between DRIFTING and "fishtailing"... .i hate it when people with FF cars tell me they were drifting.. because i know they WEREN"T.....
drifting is essentially reverse understeer. you are in an oversteer situation understeering to try and get out of it.... if your front tires had all the traction they could it would be imposible to drift cause you would pull out the exact second you got in one.
Old 06-03-02, 08:06 AM
  #37
LexFather
Guest
Posts: n/a
That dude SC_Speed was pretty accurate in explaining the differences. THe GS is a high powered RWD car, so oversteer can happen pretty easily if u are not careful. U want to let off the gas and point in the direction of the curve. DO NOT BRAKE!!! Basically instead of you going into a turn easily, you go to fast and your front wheels are pointing in one direction but your rear is sliding either left or right (like your car is slanted).
In understeer, if u let off the gas too much, u may go into oversteer, so be careful to point in the direction of the curve and keep the same speed. Like he said it is HELL to get out of, but it rarely happens to RWD cars to me.
Drifiting requires loss of traction, huge wide tires make it harder to drift on dry pavement, you need to try it in the wet. Also it helps if the car is light.
Old 06-03-02, 08:07 AM
  #38
CSHFLW
CSHFLW's Avatar
Alot of drifters use controlled e-braking to slid the rear around...how would you ever hope to do that in a GS?
OK....lets try this again...
#1 THE GS IS NOT A RACE CAR
#2 THE GS IS NOT A DRIFT CAR
and before any one gets disappointed at the strip....
#3 The GS IS NOT A DRAG CAR
Old 06-03-02, 10:18 AM
  #39
meZoom!
Super Moderator
meZoom!'s Avatar
lexusrules, although it's not the norm, it is possible to drift properly in a ff car. the techniques are different, but it can be done.
  #40
CamRen
CamRen's Avatar
If its not a rrace car or a drag car or a car that should be pimped out and not raced.....
then Why do you have an INTAKE, COLD AIR BOX, SAFC, EXHAUST???
Those are all PErformance mods... and go on RACE CARS/ WANNA B Performance Cars....
not flaming.. just a little confused.
Old 06-03-02, 10:20 AM
  #41
CamRen
CamRen's Avatar
Tranny cooler??? why do you even need that on a BPU'd car??
Old 06-03-02, 10:36 AM
  #42
LexFather
Guest
Posts: n/a
That was kinda funny!
Yeah a proper hand brake would help too.
Did ya'll see those BMW films, freaking awesome!
Old 06-03-02, 11:15 AM
  #43
CSHFLW
CSHFLW's Avatar
Havent' you seen my engine bay?????
It's all looks....
I mean, an intake/exhaust really adds very little power....I am just hoping to get back to stock power after the wheels and system. But I bought it because of the sound and the looks....plus some times intake/exhaust makes a car drive alittle better, not this case though.
We all bought GS's because of the looks....
Old 06-03-02, 11:17 AM
  #44
Richie
Richie's Avatar
Camren, sorry to hear about the bad luck, hope the damage is not too bad.
Old 06-03-02, 11:24 AM
  #45
RacingAristo
Guest
Posts: n/a
Wow, I haven't seen any GS3 with 20" chrome drifting in action. You can drift GS if you know how but it's really tough IMO. I'd suggest you to take some "drifting school" before you do it without any instructor beside yah.
Quick Reply: Thanks to all the "Drifters" i screw'd up my Car!
