Need Ideas..After oil change..my GS vibrates
I should have just did a regular oil. Since i luv my baby, i went ahead and had power steering and emisson vac clean. Now when i start the car it run ok, But once am driving and step on the brake. The car vibrates.. NOT THE RPM but just the car itself. The engine seems to be running fine. Bcos once i accelerate you don't feel the vibrating.
This will continue after 30mins of driving and then it stop. Help! Ideas!
Check your bushings. It could also be a sticky caliper.
The stock bushings on these cars are rubber so it provides a floaty and smooth ride... Since it's rubber, they wear out over time due to natural elements.
Replace them with Daizen bushings if you can. The first one I would check is the caster arm bushing (lower control arm bushing). Members have stated at it's extremely difficult to get the bushings out, but DruMnBaSS (a member) has a great DIY thread. I'll link you to it.
Daizen DIY
These are supposed to be the best bushings you can get and they're made of polyurethane so in theory you'll never have to replace them again.
I'm not sure why it would suddenly stop after driving for awhile, but those are the only ideas I have.
Daizen DIY
This was actually my problem after doing $80 diagnostic on the car.. P1349
https://www.clublexus.com/forums/gs-...ve-filter.html
Here is another followup that anyone might want to do.. I am yet to try this since it's dark have to wait till tomorrow.
What a throttle body? While @ the technician store he had ask me to go look for throttle body cleaner. I was like WTF is he talking about
https://www.clublexus.com/forums/gs-...ttle-body.html
Mass Air Flow sensor. It's a sensor that tells the car how much air is going into the engine which in turn helps regulate fuel/air mixture. It is located on the intake piping and is held in by 2 philips screws IIRC.
last time i got a blocked vvti oil control valve my error codes came on the dash. the dealer fixed it and this was just when i bought it, i've been using mobil 1 ever since so using good quality oils should help.
I also did a DIY power steering fluid change, the one with the hobby shop bottle that sucks up the oil. I did the incremental change, so about 4-5 changes / week and now my fluid is pinkish(used about 2L over the period).
I did notice a little more vibration after doing the oil change, but it might be because the power steering is now smooth, you notice the other vibrations??
Check your engine/transmission mounts also.
bentleymp2
Suspension and Brakes
01-08-16 09:28 AM
lyonkster
04-27-10 09:55 PM
