found a new secret about our cars!!!
Old 06-03-02 | 08:31 PM
power3dfx's Avatar
power3dfx
Default found a new secret about our cars!!!
1. Put the key in the ignition, but don't turn it. Push and hold the reset counter button. Don't release it.
2. Next turn the key to the accessory on position. NOT starting your GS, but just to the first click. Leave the key there.
Keep holding it for about 10 sec., then two characters will come up. press the trip again to new numbers come up. i barely tried this, so give it a shot. let me know what you get from this
Old 06-03-02 | 08:33 PM
GSquicksilver's Avatar
GSquicksilver
uh..what exactly do you see??? 0.0 miles
Old 06-03-02 | 08:44 PM
GS400_PUSHER's Avatar
GS400_PUSHER
So !!!!! What is it gonna do, tell us first!!!!:eek:
Old 06-03-02 | 08:45 PM
DaveGS4's Avatar
DaveGS4
Forum Administrator
Default Re: found a new secret about our cars!!!
You get about ten guys sitting in the garage around midnight (I'm not one of them ).
MrSypher's Avatar
MrSypher
Right, You want us to some stupid ***** to our car with out knowing what is going to happen????
Old 06-03-02 | 08:55 PM
rominl's Avatar
rominl
exclusive matchup
CL Folding 10,000
let me go and see..... wait, i don't even have a gs yet @_@
tell us man!
Old 06-03-02 | 10:32 PM
power3dfx's Avatar
power3dfx
ok well there is a reason why i tried this. my cousin showed me this on his 99 mustang. on the mustang, it shows so many options, rpm speed, car speed, fuel, oil, etc....
so then we tried my car. after about 10-15 secs. the odo went away and in the middle of the screen, it showed SP or maybe it was 5P, i couldnt tell exactly. press the button again it shows two more numbers, there is about 4 or 5 of them.
i am going to try it again. we did it twice so far. ill let you know more details, in a couple min.
by the way i have 2k gs4 platinum series.
someone else try this too, i know there is a secret place we can go, the mustang did.
Old 06-03-02 | 10:34 PM
power3dfx's Avatar
power3dfx
by the way, the mustang was done like this, go to http://mustangworld.com/ourpics/fcar/dtcodes.htm
thats how he learned to do on the mustang
Old 06-03-02 | 10:48 PM
Hermosa's Avatar
Hermosa
Sounds like you may have found a diagnostic test. Lexus puts these things in the car.
For example in my SC I can do a diagnostic on the AC by:
Turning the ignition switch on while pushing in the AUTO and REC switch simultaneously.
All indicators flash 4 times and then the error codes will show up for the AC.
Old 06-03-02 | 10:51 PM
power3dfx's Avatar
power3dfx
i just tried it again.
details:
turn key once, press and hold reset button. turn key to the last one, the last place you can go before turning the car on. this is the position where youre displays light up too. keep holding the reset button for 20-30 secs., then let go. you should see 5p show up where youre mileage is usually displayed. then press the odo/trip button thats right below the reset button. the next message i got was 7A. pressed it again and got Fu. next was 7e. then back to 5p again. i also drove the car around with each of these displayed, no difference though.
Old 06-03-02 | 10:53 PM
power3dfx's Avatar
power3dfx
finally, this went away after 5 min. of driving, or if you turn the car off and on again. maybe its nothing, but hopefully it does something. if anybody else can get this to happen, let us know. i am going to try this in my friends 94 gs3 and 2kgs3.
Old 06-04-02 | 10:00 AM
blue wax's Avatar
blue wax
< maybe its nothing, but hopefully it does something>
yezzzzzzzzzzzzz.....
your engine will explode after another 7 minutes......!!!!!!
LOLOLOLOL
Old 06-04-02 | 10:17 AM
2SAVVY's Avatar
2SAVVY
I guess before playing around with this you should of found out what if anything it does to your car.. Just my 2 cents!
Maybe DevilDogIS300 can give us some insite or any other Lexus Tech guys that come on CL??
Old 06-04-02 | 02:14 PM
GS400_PUSHER
Yeah If you don't know enough about it I wouldn't do it!!! "The only dumb question is the one thats not ask" So I am gonna ask a Lexus tech first
Old 06-04-02 | 05:40 PM
VVT-i's Avatar
VVT-i
Don't waste your time on this. Without Repair Manual those numbers doesn't mean anything. If there's something wrong with your car, you'll know it. The numbers are for Multiplex ECU to recognized where the signal is coming from, such as Door ECUs x 4, Steering ECU, A/C ECU, Memory Seat ECU, Mirror ECU, Body ECU and so on... The first set of numbers is Physical address( where it's coming from). the second set is logical address. I got a headche already, just to think about it. Don't.
