Car Vibrates When Idle
Hey guys, anyone of you have this problem? I noticed my car tends to vibrate a bit when I'm shifted into D and idled, but when I turn on my AC, the car is smooth. Any info would be appreciated.
GSquicksilver:
Exact same thing happens to me, but I don't know why. I run my AC most of the time, so I don't notice it all that much.
I've changed my plugs once and don't recall much of a difference in the rough idle... Could this be TPS related?
I just changed my plugs a few days ago. Got the OEM Iridium plugs too and my car is at 60K miles. It's still vibrating even with the new plugs. I read a while back about something TPS. Can someone give more info on this please???? Thanks!
GSquicksilver
That normal condition with A/C off. It's the programming in the ECM, all the GS doing this. You will feel more when driving for a while and comes to complete stop with A/C off. The car almost shut off and the idle is below 500 rpm. Don't worry your car is fine.
I had almost the same problem as you just mention back in August. But I don't really use my AC that much. I took my car in (99' GS4) every two to three weeks and they said that they couldn't find what I was describing to them (the vibration at idle).
After about seven or eight time in telling them about the same problem, he finally took me over and talked to the tech. I told him what was happening. The tech. knew what I was talking about. It turns out that the throdle body was bad, it was about a thousand dollar part but it was cover under my warrenty.
After that part was fixed, the problem went away. I'm just now a little uder 35K miles on my car. When this was happening I was at about 27K miles.
I would just ask them to look into changing the throdle body (hopefully you still have warrenty).
Chan
Chan
Getting Ripped Off?
My first post so please take it easy on me!
After twice getting check engine lights and vsc lights go on the past 1500 miles my local dealer, Serramonte Lexus in NorCal, told me I needed to replace my TPS. Part was ~$250 and labor ~$150.
Does anyone know of a reputable mechanic in the area that could do this work for me or a contact at another Lexus dealer that won't charge me these prices?
I've had nothing but good experiences with Serramonte Lexus up until this point so I am kinda surprised (pissed more like it) after searching through the threads that this shouldn't cost no more than a hundred bucks. They even offered me a courtesy vehicle to drive to LA over the weekend since my car started acting up before the trip. Suffice to say I had no problems during the weekend.
Mark Mac
Mark Mac
Originally posted by GSquicksilver
thanks for all the info guys. so do you guys think this will be covered under the powertrain warranty? i have like 10k left on the powertrain.
Mr4btTahoe
04-03-17 01:34 AM
