DIY - Daizen Caster Arm Bushing Installation - lots of pics!
Old 03-21-10, 08:53 PM
lyonkster
lyonkster's Avatar
Default DIY - Daizen Caster Arm Bushing Installation - lots of pics!
This weekend I installed the Daizen caster arm bushings, and took some pictures along the way. I did the whole job in 3.5 hours, counting from getting the car up onto the jackstands to when I test drove it. This was my first time doing this, I think I could do it in half the time if I did it again.
I got the bushing kit from TM Engineering. I guess I was lucky, because I got the parts within ten days of ordering, and Todd was great in his correspondence with me.
A tricky part of this job was getting the old bushings out. I did not use either the "torch it out" or "cut it out" approaches, instead I sprung for the $99 Harbor Freight 12 ton press, and pressed them out. I would recommend this approach - it is fairly easy, plus you get to keep the press as a reward .
So here is the step by step DIY. As a disclaimer, I am a fairly competent DIY-er. If you are not, or are not sure of what you are doing, this job may not be for you.
If, like me, you are only doing the caster arm bushing (#2 Lower Suspension Arm, in Lexus-speak), there is no need to separate or remove ball joints, springs, etc. Some writeups suggested to do that, but there is no need.
1. Jack up the car and put it safely onto jackstands. Remove wheels/tires.
2. Remove the bolts and nuts holding the suspension member brace and the two strut bar brackets. 10 fasteners total - two bolts in the front of the brace, and then two bolts and two nuts at each strut bar bracket. Below is a photo of one strut bar bracket, and its four fasteners. (For those who noticed - yes, the arm already has new bushings installed, because I initially forgot to take this picture, and took it at the end of the job).
3. Here is a view of the bushing end of the arm, the bushing is now exposed.
4. Here is a view of the two bolts holding the caster arm to the #1 Lower Suspension Arm (the ones with "11" on the head).
5. Here I am removing the two bolts holding the caster arm to the #1 Lower Suspension Arm. I used a 25" breaker bar, and still had to give it a heck of a heave-ho before the bolts loosened.
6. Now the arm comes right out, as promised.
My bushings were pretty much shot, as you can see by the big crack that is visible when I pried on the bushing.
7. You cannot press the bushings out without lifting the lip of the bushing first. I clamped the arm in a vise, and used an air chisel to lift the lip. Here is a portion of the lip lifted.
8. Here is what you want to end up with, with the lip lifted all the way around.
9. Now I placed the arm and the bushing into my 12 ton press.
10. Here is a closeup, just after starting to press.
11. Here is the bushing after some movement. It made quite the "POP!" when it first moved.
12. Here is the bushing out of the arm.
13. You'll want to debur the arm, remove any rust, and then apply some of the Daizen supplied lube to the arm and to the bushing.
14. Now it's time to install the Daizen bushing in the arm. Line up the bushing and the arm in the press, and proceed to press.
15. At first it looked like the lip was too big to slip through the arm hole, as the bushing was flexing and bulging quite a bit. I was worried that the bushing might collapse under pressure. But it did not, and with more pressure it popped right in.
The next step was getting the arm back into the car. It ended up being the most frustrating part for me. The problem is that the Daizen bushing is much less compliant than the original bushing, so it is difficult to simultaneously line up both the bushing with its stud, and the caster arm with the #1 control arm. I initially tried installing the control arm bolts first, but then I could not slip the bushing over the stud. I even tried to raise the control arm with a jack, but no matter how high I raised it (to the point of lifting the car off the jack stand), things still would not line up. So I ended up using the approach I show here.
16. Slip the Daizen sleeve onto the stud. The larger hole goes up; it won't fit the other way.
17. Now position the caster arm in place, and slip the bushing over the Daizen sleeve.
18. Place the strut bar bracket over the stud, and loosely install the retaining nut, to keep the arm from falling off the stud.
19. Now it's time to install the bolts holding the caster arm to #1 control arm - but as you can see, the geometry is off. If you try to install the bolts like this, you'll strip the threads and will end up with a big mess on your hands.
20. To line things up, I grabbed a large adjustable wrench, placed it over the caster arm near the bushing, and rotated the arm until the bolts up front lined up.
21. Reinstall the suspension member brace, torque all the bolts and nuts. Caster arm to #1 control arm bolts: 122 ft-lbf (my shop manual says 180 ft-lbf, and I believe that, given how hard they were to loosen); Caster arm bushing stud: 112 ft-lbf; strut bar bracket and suspension member brace bolts: 43 ft-lbf. Reinstall the wheels, and go for a test drive
I have not driven the car enough to see if it cured my clunking, or how it improved the drivability (if at all), but I wanted to post this thread before I forgot all the steps. I'll report on the driving impressions later on.
BTW, on further reflection, if I did this again, I might try another approach for getting the arm back in place: first loosely install the bolts holding the caster arm to the control arm, and then use some kind of a pry bar inside the bushing sleeve to force it to rotate and line up with the stud. But I haven't tried this, so I don't know if that would work better or worse than the approach I showed here.
Hope this helped. I would welcome any corrections or clarifications that I might have left out.
Old 03-21-10, 09:09 PM
GSteg
GSteg's Avatar
Nice job!
The air chissel definitely helps. Thats the method I used in getting mine out, and it's also the fastest way.
Old 03-21-10, 09:52 PM
sakataj
sakataj's Avatar
nice, i know where i can send my # 2 LCA to have the bushings done. :P good job
Old 03-21-10, 10:03 PM
McKrevice
McKrevice's Avatar
subscribed for when I do this, someday.
Old 03-21-10, 10:14 PM
rgarjr
rgarjr's Avatar
Great pictures man. Did you only get a chance to work on that big bushing or did you do the UCA ones as well?
Old 03-21-10, 10:37 PM
TxLexus400
TxLexus400's Avatar
nice i will definitely save this diy.
Old 03-22-10, 04:12 AM
runyun
runyun's Avatar
thank you, ordered my TM set over the weekend. the caster bushing was the main reason.
thanks for your efforts
Old 03-22-10, 06:23 AM
Rob Daddy
Rob Daddy's Avatar
Great write up. Are these back in stock? I need it for a 99 GS.
Did you install the rest?
Old 03-22-10, 06:32 AM
lo_dit
lo_dit's Avatar
awesome write up. just the way one should be. saving this for future references!
Old 03-22-10, 08:10 AM
lyonkster
lyonkster's Avatar
Thanks for the nice words folks, I am happy to give something back to this forum where I learned so much from others.
I actually might consider it, seeing how many folks have trouble getting someone to do this for them. Of course with my luck, when I work on someone else's arm, something will go terribly wrong.
I have the whole set of bushings, but don't plan to install the others, since I do not want to stiffen up the ride. So I plan to leave it at this.
Old 03-22-10, 08:32 AM
sakataj
sakataj's Avatar
hmmmm....maybe stock up on some 2001+ bushings and some # 2 lca's and sell them. i will buy one from you...
Old 03-22-10, 09:49 AM
sivikvtec
sivikvtec's Avatar
To get the arm lined up at the end, couldn't you just jack up the suspension on that side (putting the jack under the brake rotor) until everything lined up instead of using the adjustable wrench?
Old 03-22-10, 09:53 AM
joshoowa
joshoowa's Avatar
You can always take off the arms yourself and drop by any knowledgeable shop to get them to remove and press in new bushings. I paid 50bucks to get all my bushings removed and pressed in was pretty cheap IMO. I also just went to town removing all the components lol didn't really care for any formalities when removing...now when I reinstalled everything I used the lexus mechanic book.
Old 03-22-10, 10:57 AM
lyonkster
lyonkster's Avatar
I tried, and it helped a bit, but not enough to line things up. I had the whole car lifted by the ball joint off the jack stand, and things still did not line up.
Old 03-22-10, 11:07 AM
GSteg
GSteg's Avatar
Easiest way to line up is to remove the spring/shock assembly (should be quick). Then you use your jack to lift up the LCA no.1 until it matches up with the caster arm. The process took me under 15 minutes, and I didn't have to wrestle with anything.
Quick Reply: DIY - Daizen Caster Arm Bushing Installation - lots of pics!
