Easy or not, you would be taking out the high beam bulb altogether if you did that.
The later model gs uses the high beam bulb at a lower wattage for DLR.. Your thinking of the small wedge bulb in the same housing which is the parking light.
Well whoopsies I guess your right always thought it was that bulb cuz when you turn on your actual head lights it switches to that bulb.... just found this out now.
Hahaha I was getting ready to snap a pic a rage it how I was right then I realized wowzers im a dumb-dumb idiot Thanks for the lighting 101 lesson though
Thanks for the replies everyone! That's good to know about turning the car on and off to turn the lights off with the parking brake on. That pretty much solves my problem. I like the way the lights look when i'm driving around - it's just when I'm sitting somewhere and they won't go out that bothers me!! Problem solved I knew I could find my answer at Club Lexus! SWEEEEEEEEEEEEEEEEEEEEET
yes...but on some yr and idk why the relay mod works and on there other that jumper in the fuse work..cause on my 00 i tried the relay nothing but the jumper in the fuse worked no problem
