GS300 calipers and ls400, supra, soarer calipers
hi guys
i have few questions please.
1. any place to buy cheap calipers for my gs300 mk2 1998 ?
2. any place who refurb calipers
3. will soarer, ls400 or supra calipers fit gs300 mk2 or any other make / model without any wheel / suspension modifications.
my both front calipers are sticking. i have checked and its not rubber boots or slider pins. lexus quoted me £720 inc parts and labour for front 2 calipers.
any help would be much appreciated
cheers guys
cheers guys
Junk yards/Ebay/ Part stores.
Lexus sells the rebuild kits or the calipers, has to be a reason why yours are sticking.
Supra's are a direct fit, the LS400s require modification of the a bolt, there are threads on this. However with any setup that you go with it would require at least 17" wheels and big brake clearance. If you are running the stock GS 17"s then you would require a 15MM spacer.
OP if u search u could find out all the info on what brakes fit your car. depending on your rim size there is a BBK kit for sale in the classifieds
