Nakamichi head unit wiring
Old 04-11-10, 06:35 AM
  #31
jcastaneda
jcastaneda's Avatar
The speaker was too wide to do that...I tried several different options. I tried to use the old speaker cases, I tried to use MDF spacer...I cut a 1/4 , 1/2, 3/4 spacer but it either ran into the window or the panel wouldn't go on.
Old 04-11-10, 06:59 PM
  #32
porn-adkt
porn-adkt's Avatar
question? what did you do for the two antenna male plugs from the car? did you just hook up one? or did you plug both of them? im trying to find a Y splitter for the antenna but have no luck finding the right one that will fit the regular and small plug.
Old 04-11-10, 08:54 PM
  #33
jcastaneda
jcastaneda's Avatar
I just used one...I didn't look for a y adapter....it still works good.
Old 04-11-10, 11:14 PM
  #34
Kyle Harty
Kyle Harty's Avatar
Looks like it might be too late now, but the trick to the baffle is a 1/2" baffle the size of the stock enclosure with another 1/2 or 1/4" ring behind the speaker itself. I fit my mids which are 7 1/4" actual diameter with 3" mounting depth using this method, the door panels barely fit back on, took some grinding of plastic around the grill but it worked.
I'm not totally opposed to the tweeter mounted into the rear door panel but I put the rear tweeter on the same baffle as the mid in the stock location. For me, the rears are gonna be toned down most of the time anyway.
Old 04-12-10, 04:16 AM
  #35
jcastaneda
jcastaneda's Avatar
yea....i didn't bother grinding the under side of the panel...i took a huge risk messing up the covers when i cut into them...i know i know i already did when i cut through them. But I was able to make it look clean...which i am thankful for!
RanGer498
08-21-06 11:27 AM
k00lrav
01-06-06 08:22 PM
pcroland
GS - 1st Gen (1993-1997)
03-08-05 03:54 PM
abboushi
11-01-04 09:58 AM
Quick Reply: Nakamichi head unit wiring
