Ok, I've searched around in all the forums and couldnt really find a DIY on how to install a Apexi Neo. Do you drill through the firewall? If so how do you run the cords? I plan on using a boomslang harness, Does anybody have a good DIY out there or some help for me to install this thing. Thanks for the help Guys!
punch a slit in the rubber grommet below the brake booster reeioir. Tape a clothes hanger straightened out thru the slit and see where it comes out. should be in front of the brake pedal.
Tape your SFAC wire to it & pull it back into the engine side.
Yeah really, But how do you get that damn ashtray out?
I havnt got the sways yet, Im guna hold of for a while and let the mod bug cool down.
Here's what you want to do, my friend.
1. Turn the car on and move the shift **** down to neutral and put the parking brake on or if you want to be a real dare devil, hold the brakes while the car is in drive.
2. Open the ashtray so you can get a better grip on it.
3. Push down slightly and pull towards you. Wiggle it around a bit and it should pop right out.
4. Don't forget your car is in neutral/drive.
Mine had a hole in the firewall, just had to take out the rubber plug. It was big enough for the wires. I'll try to get a picture up later if you hadn't done it already. This installation from ashtray to engine bay is easier then you think.
follow below....its really easy to remove the ashtray
