Is there another alternative to these sidemarkers???
I am looking for an alternative to these typical aftermarket sidemarkers for the GS. Does anyone know if someone makes sidemarkers with just a WHITE cover vs these aftermarket CLEAR cover as seen in the picture.
GX and 2IS Moderator
Drew,
there is an alernative, but it requires you to make the hole behind the light a little bigger. If you use the clear markers from (i think the rear) of Honda Accord (not sure what year) you can get the "nicer" IMHO, clears that you are referring to. Aside from that no there is no clear marker that has the same reflector pattern as our existing orange markers.
