VSC + ABS + VSC Off lights.
Old 03-29-10, 08:34 PM
vwynn
vwynn's Avatar
Default VSC + ABS + VSC Off lights.
Ok i was wondering what causes those lights to come on?
I know its a common problem when those lights + the CEL engine comes on like the throttle sensor n what not... but i dont have the CEL on or anything.. just the VSC, ABS, and VSC Off...
whats a list of things i should go check so i can fix it?
The speed sensor looks fine.. no breaks in the line. anything else?
Car drives fine with no "limp" mode or anything. Feels like a regular car just with the lights on and no traction control (due to the lights assuming)
Old 03-29-10, 10:12 PM
sakataj
sakataj's Avatar
did u put a meter on it to make sure, as it visually could look fine
this happen on the new car u JUST bought?
Old 03-29-10, 10:49 PM
shvc1991
shvc1991's Avatar
Have you done any suspension work recently?
The speed sensor is usually not the problem, it's the ABS/VSC sensor. It's very delicate and cable is very prone to breaking. Jefftsai has a nice DIY on how to fix it.
Here's the link. The pictures don't seem to be working. Maybe you can contact Jeff?
ABS/VSC Sensor Fix DIY
Old 03-29-10, 10:59 PM
sakataj
sakataj's Avatar
oops, i thought that was what he was asking about....i really need to read lately
Old 03-29-10, 11:04 PM
shvc1991
shvc1991's Avatar
It's 2 in the morning. Nobody reads at 2 in the morning.
Old 03-29-10, 11:25 PM
vwynn
vwynn's Avatar
its 11:24PM here in socal
hmm does anyone have a pic of this ABS wire? Jeff's pics are dead :/
Old 03-29-10, 11:26 PM
vwynn
vwynn's Avatar
i personally have not done any suspension work but the previous owner did. I installed the Intrax Swaybars and made sure i put the fronts on correctly. but thats it...
Old 03-29-10, 11:35 PM
sakataj
sakataj's Avatar
see im going by info like this....where he is saying the speed sensor is the same so i was thinking he was talking bout the same thing
https://www.clublexus.com/forums/2ge...t-working.html
art had a pic in this thread but i even tried looking in his photobucket pics and didnt see it...maybe email hi and ask him
https://www.clublexus.com/forums/2ge...999-gs300.html
Old 06-06-10, 08:10 PM
egbenj
egbenj's Avatar
Did you find an answer to this? I have the same scenario.
Old 06-06-10, 09:02 PM
D-Boi
D-Boi's Avatar
i have the same problem on my gs and ive had it at a few different shops and even at the dealer and they havent figured it out, right now its at a shop where they checked everything over and every sensor is fine besides a speed sensor on the rear pass side, they ordered a new one, and if it doesnt cure the problem i wont have to pay nothing, i hope it does though im sick of it
Old 06-06-10, 09:17 PM
hurricane
hurricane's Avatar
same problem here!! check engine light goes off and on also!!
right now i have same problem as above and check engine is off!
Old 06-06-10, 09:57 PM
vwynn
vwynn's Avatar
Hurricane: since you got the CEL run a scanner.. for us guys with the other lights excluding CEL we cannot run a scanner :/
i havent had time to dismount my wheels and check the rear sensor yet since i have finals but imma see if anything is wrong..
ill try to do run a multimeter to it to see if the line is good.. but gotta take care of finals first. until then goodluck to all of us! LOL
Old 06-06-10, 11:17 PM
sam430
sam430's Avatar
did u install the sway bar correctly? I matched mine to the oem, but the oem was installed incorrectly... so I got vsc+abs on. I had to flip the sway left to right or push the retainer to the side a little bit.
Old 06-11-10, 12:53 AM
ydjy
ydjy's Avatar
Why exactly wouldn't you be able to run a scanner? ABS is just another computer controlled system.
In fact, you can find information on pulling the codes from ABS ECU with or without the scanner here.
Old 06-11-10, 05:18 AM
bboystrobe
bboystrobe's Avatar
I have the same problem. I was told it was my brake master cylinder/booster as its a common problem in 2nd Gens. Keep us posted.
Quick Reply: VSC + ABS + VSC Off lights.
