CA cars slower?
This may be a dumb question, but do CA emissions on the GS (or any car) make it slower than a GS from another state that may have more relaxed standards?
All cars in the United States are manufacturered the same as far as emissions. The only thing that sucks for us is that we can't mess with the catalytic convertors on our cars to improve exhaust flow otherwise they don't pass smog (especially OBD-II). In some states, they don't even smog and for all they care you can drive around with open headers all day. Some states use higher octane gas than 91 therefore they may have slightly improved power strokes. IMO, I think our fairly high compression cars would fare best with 93 octane.
Super Moderator
actually i heard that my 95 ES is 5hp less than the same model in other states. and i just got a smog check and i when i got my report back, i notice that in one of the categories i BARELY passed. so, i dunno what that tells you but california emissions laws suck but i guess with all the cars running around we need it.
The ODB-II standard was set on ALL auto manufacturers inside the United States by EPA, SAE, and CARB effective January 1, 1996. Many manufacturers started making cars OBD-II complaint back as far as 1994 though. This means that all cars from 1996 on should be universal, and many 1995 models as well.
Super Moderator
Originally posted by GSquicksilver
whatever happened to octane 92 we used to have in cali like a year ago?
Cali premium octane dropped from 92 to 91 last summer largely because of the ban on MTBE. MTBE is the current octane booster they're using in our gas, but it corrodes and leaks into ground water so CA is junking it across the board. The new additive, ethanol, is a patented Unocal blend, which will cost non-Unocal refineries more to make (royalties). So in order to combat rising costs (and lower profits), they dropped the octane to 91 because it was cheaper to make. Of course we still get screwed in the end because we're paying the same and getting lower octane, but 91 is still safe for luxo cars. Not optimal, but safe. FI cars is a different story though...
California does have higher emission standards than any other state but that should not effect your cars performance. A GS has ultra-low emissions which easily meets the CA emission laws. The only thing that would slow your car down is the type of gas in CA. Can 93 octane gas be found anywhere in California??
i know in south cali, west LA (close to westwood if you know where it is) there is a 76 gas station where you can get 100 gas. but it comes at 5 bucks per gallon. you can constantly see cars like porsche and ferrari pumping gas from there. and usually what they do is to pump in 2 gallos of the 100 and then use 91 for the rest
Yeah, what rominl said. There are some really old relic Unocal 76 stations scattered around that serve 100-octane at around $6.00 per gallon. You can search for them at www.76.com . They are the only ones in CA that have higher than 91-octane.
