Aftermarnet sub - OEM amp
I did quite a bit searching today (Here and Google) for this type of setup. I didn't find anything. I don't want this turning into a sub discussion, just a simple (if that) yes or no. I'm hoping I can get a little more bass with the stock system. Thanks.
I've heard good things about this amp.
AudioControl LC6.
http://www.audiocontrol.com/31215/pr...Converter.html
Quick-VR4 is using this setup in a custom box with a 12". But i keep hearing the stock open air design isn't to efficient. So it's hard to see any gains from using it.
AudioControl LC6.
I would have to say No...... any SUB is going to require more power to produce more bass.... esp if you underpower a sub, you may not even get as good a response as the stock sub... which hits pretty damn nice for a stock system
True, kind of.
I don't think you guys understand what I'm asking. Keeping everything factory except the sub. And I don't expect a lot of extra bass. Just be able to handle a bit more power then the oem unit. When the volume is half way the sub is at it's max. My door speakers can handle it, but the sub isn't keeping up.
True, kind of.
I just upgraded the ML sub on my 02 GS430 and it sounds sick... The ML sub is absolute crap after seeing what it looks like. I will put a full post up this week with photo's. It was a simple swap... I dropped in a JL Audio 10iB4 10" woofer 8 ohms which I bought from Woofersetc (http://www.woofersetc.com/p2752/10IB...-Subwoofer.htm) Then used a 4 channel Alpine Amp which I already had to push it... All you really need is a mono amp. Had the guys at Bestbuy install it. It sounded clean, the bass is crisp, tight with no rattling, did i mention loud.... Love it man.. I've read a lot of different posts on here and decided this is the best possible set up. Someone else recommended this Sub but they used the stock ML amp. It would work fine but if you can afford an amp to push it, go for it. You wont regret it. Side note i put the balance 2 bars towards the rear speakers since the front is noticeably louder, your choice.
I used an additional amp to power mine. Using the same wires from the stock Amp that runs to the sub i tapped it to my secondary amp that solely powers my sub.... and yes i used a capacitor to protect my OEM amp to not draw more power than needed. Up and running for like 6 months or so and no problems what so ever... It sounds amazing, while maintaining the classy sound of the Mark Levinson system, but with the added bass when needed... hope that helps....I will post pics online for you guys...
I recommend a 10" woofer fits better. Also depending on the wattage of your woofer you don't want to under-power your sub which can damage your OEM amp by drawing too much power. If you can afford a cheap Mono amp or bridged 2 channel amp then that's the best way to go...
I suggest you run a aftermarket amp to your stock sub. That's what I did. It knocks harder. If you don't want that much bass and want to keep the sound clean. You can just adjust it through the aftermarket amp.
The OEM won't let you adjust the bass to how you want.
