Old 12-15-14, 03:58 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Tires and Wheels Guide
Print Wikipost
NEED ANSWERS ASAP!! wheel bearings
Old 01-29-17, 11:23 AM
lexo98
lexo98's Avatar
I would also check for a bent rim...
Old 02-05-17, 04:01 AM
GSdre
GSdre's Avatar
Unhappy The verdict
Originally Posted by Mr Jokster
Is it wobbling while you're accelerating, or when you're braking? If its while you're braking, well then it could be your "bad brakes". Rotors could be warped; warped rotors will create a wobble. Testing joints is easy, raise the car and see if you can move them by hand. Grab the tire on each side and see if you can get it to move side to side and/or up and down.
Also, check your tires for tumors as well as your lugnuts.
Thanks for the reply, after careful inspection. I found out the driver side inner tie rod is blown , and rotors are warped
Old 04-26-17, 10:51 AM
LexusK
LexusK's Avatar
Are you guys going with OEM bearings? How much did you get them for? Would Autozone or RockAuto be an acceptable alternative? Autozone because I heard they have a lifetime warranty?
And do these all come with the cap, nut, and snap ring? or would it have to be purchased separately?
Old 04-26-17, 12:00 PM
vipXjunky
vipXjunky's Avatar
i replaced mine with a brand called Timken from rockauto like 3 years ago? And its still good. I believe it was under 100 for 1. As for the caps, nut and snap ring, u will need to buy them seperatly. Hope that helps!
Gil Smash
04-19-13 05:23 PM
Swif
Performance & Maintenance
01-25-12 06:17 PM
Mr.lex89
21
08-26-11 05:30 AM
MicaISF
IS F (2008-2014)
01-05-10 02:29 PM
status....
GS - 1st Gen (1993-1997)
08-12-07 06:57 PM
Quick Reply: NEED ANSWERS ASAP!! wheel bearings
