HID issues. Sometimes 1 of the 2 ballast not powering up
whats up , I have a 01, GS3 . non hid. I put the retro-solutions hid kit on..install was a breeze, but I have a intermittent problem with one of the 2 ballast not powering up (sometimes driver side, sometimes passenger side). i would have to turn the head light switch on and off to get them both powered up together. Do i need to up the relay or fuse?
Check the relay and the connection points. I think if the relay was bad then both ballasts would fail together.
What kind of aftermarket kit did you put in? Did it come with a relay?
whats up , I have a 01, GS3 . non hid. I put the retro-solutions hid kit on..install was a breeze, but I have a intermittent problem with one of the 2 ballast not powering up (sometimes driver side, sometimes passenger side). i would have to turn the head light switch on and off to get them both powered up together. Do i need to up the relay or fuse? ![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
i bought a relay harness from a vendor here, it didnt fix my issue so if OP wants to buy it, i will say it cheap. its for 9006 bulbs....dont know (and to lazy to look) if the oem non hid's used 9006 bulbs i know my fogs did
I had the same problem with my passenger side not wanting to turn on after lots of troubleshooting i came to discover that heat was killing the ballast and when it would get hot it wouldent want to ignite. I moved the mounting location of the ballast to a much better spot not surrounded by wires and other components and it fixed my problem. My 2 HID kits were purchased from Ebay and did not have a wire harness either you also need to check your connections to ensure they are tight these kits are really sensitive.
smokyis350
07-24-09 12:26 AM
